Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
A Note On Ez-ai/rafiki
A Note On Ez-Ai/Rafiki
EZ-AI development is on hold right now, well kind of...
We are in the process of working with some services that will allow the capabilities of EZ-AI to be far better than what they currently are. These include Wolfram|Alpha and IBM BlueMix/Watson. Speech Recognition will be performed through Nuance Cloud services. Advanced vision features will be available through OpenCV. A quick search of these services will allow you to see the end goal of what we are doing. These will be in the Rafiki project which is the primary focus at this time for CochranRobotics. We will release a limited use version for free which will replace EZ-AI. All of the current features of the EZ-AI database will be available through the new version. All of the services provided by EZ-AI will be available through REST queries and exposed services. This will allow plugins to ARC to be able to use these services.
There has been a huge amount of changes to what is possible since I first started working on EZ-AI. This huge shift of improved technologies has made it necessary to rework EZ-AI so that it can continue to grow and mature.
We are also toying with the idea of allowing programmers to write their own business logic layer within Rafiki. This would allow a programmer to be able to use the core services of Rafiki/EZ-AI and write their own applications with the data that is returned. It will probably be a while before this is implemented, but it is something that we are trying to make happen.
I have probably said too much, but wanted to give you all a picture of what is happening and why EZ-AI isn't being worked on directly. We hope to have our new AI available around the end of the year. There are multiple developers working on this while I find come up with solutions to other problems that arise.
As far as Rafiki goes, the pods are functioning great and additional code/abilities are being added almost daily. The models for the pods are being tweaked to expose the HDMI and usb ports and network port to the outside of the case. This will allow someone to connect a mouse, keyboard and monitor to the pod and use it as a computer if they would like. The Rafiki Bot is about 1/3 of the way printed. I am making modifications to the models as needed and reprinting some of the parts as needed. There will be 6 subsystems on this robot. 3 of these subsystems have been written and are ready to use. The other 3 subsystems cant be worked on until more of the Rafiki Bot has been printed. The 3 that are not complete are all very similar for motor control. I hope to have these ready in a couple of weeks. I should be able to show a demo of the Rafiki Bot in about a month, and then all of the robot programming starts. I will work on the charger base shortly after the robot has been completed and the pods are all working with all of their functionality.
One more thing on EZ-AI... As a part of this rewrite, you will just need to have Java installed on your computer to install and use EZ-AI. The days of the huge install will be behind us so it should make it far better in the long run. The other thing that this allows is robot platform independence. I will be working on modules in ARC to allow the features of EZ-AI to be accessible far more easily. This will probably not be worked on until December at the earliest.
Okay, going back to my robot cave. Have a great day all.
#145
Parts 10 and 11 were modified for Velcro strap for battery. The thought is to use this as a front hole and then the caster wheel hole for a velcro strap to hold the battery down.
#146
I have hated relying on the EZ-Robot community to provide updates to my projects. There are so many ways now to deliver information and while I love this community, I don't like consuming resource at EZ-Robot as my own communications channel. There are some benefits to using this community as this is probably the online community that I am the most familiar with, but I also feel bad every time that I have to make a post about Rafiki or EZ-AI.
Because of this, there are now some other avenues available to get information about EZ-AI and Rafiki. They are:
EZ-AI Community group page
Rafiki Community group page
and https://www.cochranrobotics.com
I will try to keep these updated with information as it can be released. With the community group pages, you are able to turn on or off notifications on new posts. This does require that you have a free google+ account, which isn't a bad thing anyway. I will also reply to any questions posted here about either of these two products. Hopefully this will allow those who don't care to see these updates in this community to not have to see the posts, and will help to keep this community focused on the products that it was intended to support.
Thanks David
#147
David,
The EZ-AI Community Group page is saying I am required to sign in with a Google+ account if I want to join. Is there another way?
Are we still allowed to post EZ-AI questions and discussion here?
Thanks!
#148
Yes, it is just much easier to do in Google and all of the information is in one place. Nobody asked me to move it to the Google+ page. I just feel bad about doing things through here. I will be happy to answer questions if posted here.
To use that page, you would need to sign up for a free google+ account.
On a side note, it also allows me to see the level of interest in EZ-AI.
#149
@Cochran Robotics
Dude, I just purchased a bunch of mold making materials for Archetype, so I can reproduce the shells in whatever material I'd want. Right now fiberglass/cold cast aluminum is the strongest contender, but other resins and even carbon fiber is possible. If you need molds made for Rafiki for mass production let me know if you're interested.
#150
That would be great! I will be in touch when I get this one printed out and built. Your help would be greatly appreciated.
Email me if you would so I can figure out what any limitations are. My email address is in my profile here.
#151
@Cochran Sent you an email.
#152
Thanks Doom. Will be in contact in the next couple of days. You being around Houston makes not too bad of a drive for me when needed. I am in Dallas all of the time anyway, so what's another 8 or so hours worth of driving if needed?
I will be in touch.
