Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
ARC Client Connection Question
Hi,
I'm having trouble talking to my JD in client mode. When I power him up he says "connected to network" When I connect through my browser I can connect and the buttons work When I connect in ARC I get
"Attempting connection on 192.168.0.10:23 Connected to 192.168.0.10:23 Reports EZB v4 OS With Comm 1 EZ-B v4 ID: 31-50-0-0-46-255-61-57-59-37-37-38 Setting battery monitor voltage: 7 Setting battery protection: True Setting i2c rate: 100000 Connected"
But that's as far as it goes. I can't do anything with JD, nothing works, Auto Position, RGB animator, I can even get a connection to the camera.
I've disabled my Virus software, rebooted everything, laptop, router EZ-B but still nothing
Am I missing something?
Try the JD no animator project (that may not be its name, but it is similar). If the RGB animator (or any other I2C device) cable is not plugged in fully, or there is anything wrong with the device or cable, it will lock up the EZ-B when the software tries to talk to it.
Thanks for the reply but still nothing.
Tried the cables but still nothing. If i connect in Ad hoc mode everything works fine, but nothing works in client mode
If I try to run 'init' I get
Error on line 9: Not connected to EZ_B 0
Oh. If it works in adhoc, not the i2c issue.
You are using the connection 0 slot in the connection object (top slot)?
I was connecting using slot 1, swapped to slot 0 and now everything works.
Thanks for that
Glad it was something simple.
Alan,
You have an eye for simple details...
I'm the opposite i start to troubleshot the worst scenarios:)
Have to say I was thinking the worse as well blush happy it was that simple.
Thanks again
