Shortcut Creator icon Shortcut Creator — Shortcut Creator relocated to the ARC Options menu; new manual page provides updated Shortcut Creator documentation. Try it →
Sweden
ARC Constant Crach Using Camera
Hi! My first post here, I havent used my JD for some time but now when I use the software (with the latest version) then it crach all the time.... I have upgrade to windows 10 since the last time and dont know if the problem relates to that?
I use the camera that was with the kit and when I select resolution "160x120" it crashes and the debug question appears... 320x240 works the best but craches after some 5-10 minutes. And the camera dont work in 640x480, it looks like dubbelvison and a very smal picture.
Anyone have the same problem oar maybe a solution? tired
Update ARC. No one can help you unless you're running the latest version. The log file doesn't show that you're using the latest version.
Please update and report back.
Also, please read the camera manual page to understand why you are changing resolutions?
Lastly, are you using the default jd project? The robot program tells you how to load the default project.
