Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
ARC Onboard Versus Remote Limits
If I run the ARC application on a Raspberry Pi 5 (Windows on ARM) mounted on my robot, with the robot’s controllers connected to that Pi, what limitations should I expect compared to running ARC from a separate laptop connected to the robot over WiFi? What functionality do I give up (or gain) when ARC runs onboard versus when it runs remotely?
For clarity, I mean ARC as the central control application that coordinates Robot Skills, EZB or other onboard controllers, cameras, microphones, motors, and scripts (JavaScript/Python). Please explain differences specifically for:
  • hardware connected through an EZB or other onboard controller (for example, an IoTiny, Arduinos, or servo controller boards mounted on the robot) versus devices connected directly to a PC (USB cameras, USB microphones, USB joysticks/gamepads, serial/COM devices, Bluetooth peripherals, etc.),
  • Robot Skills and vision/audio processing (for example, camera tracking and other vision skills),
  • scripting (JavaScript/Python) and automation behavior,
  • network-dependent features when ARC is accessed over WiFi (what breaks or changes if ARC is onboard vs remote).
I plan to connect an IoTiny and Arduinos/servo control boards to make the physical connections to sensors and actuators.
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
EZB Connection by Synthiam
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
If ARC runs on the Raspberry Pi 5 onboard the robot, you generally gain simplicity and reduce network dependency, but you may lose some convenience and peripheral flexibility compared with running ARC on a separate laptop and controlling the robot over WiFi.
The short version
ARC onboard the robot
Pros
  • No reliance on WiFi for core robot control
  • Lower latency for scripts, control loops, and skill coordination
  • Easier to keep the robot self-contained
  • USB devices plugged into the Pi are local to ARC
Cons
  • Limited by the Pi 5 + Windows on ARM environment
  • Fewer options for USB/peripheral-heavy workflows than a laptop
  • Some Windows x86 apps/drivers may not work on ARM or may be less reliable
  • If the Pi reboots/crashes, the whole robot brain is physically on the robot
ARC running on a laptop remotely
Pros
  • Better performance for heavy vision/audio/UI workloads
  • Easier access to a wide range of USB devices and Windows drivers
  • Simpler debugging and development
  • More comfortable for camera tuning, logging, and testing
Cons
  • Core control depends on network reliability
  • WiFi latency/dropouts can affect teleop and streaming
  • The robot still needs onboard controllers for real I/O
What changes by category
1) Hardware connected through EZB or onboard controllers vs directly to the PC
Hardware on the robot through an EZB / IoTiny / Arduino / servo controller
This is the best place for motors, servos, PWM, ADC, digital I/O, UART devices, and sensors that live on the robot.
Whether ARC is onboard or remote, these are still robot-local.
That means:
  • Servo control timing stays on the controller
  • Sensor reads happen close to the hardware
  • Motion is not dependent on USB peripherals attached to a laptop
  • The robot can keep working even if the remote PC disconnects, as long as the onboard controller and ARC logic remain running
Since you plan to use IoTiny and Arduinos/servo boards, that architecture is solid.
Useful overview:
Hardware connected directly to the PC
This is where the biggest difference shows up.
If ARC is on the Pi onboard
Anything physically plugged into the Pi is local to ARC:
  • USB cameras
  • USB microphones
  • USB gamepads/joysticks
  • USB serial devices
  • Some Bluetooth devices if the Pi’s Bluetooth stack and drivers cooperate
If ARC is on a separate laptop
Those same devices connect to the laptop instead:
  • USB camera and microphone are local to the laptop
  • Joystick/gamepad input is local to the laptop
  • COM/serial devices are local to the laptop unless bridged/networked
  • Bluetooth peripherals are tied to the laptop’s Bluetooth environment
Practical impact
If you run ARC onboard, you gain:
  • Simpler cabling for peripherals mounted on the robot
  • No need to stream camera/video data across WiFi just so ARC can "see" the camera
If you run ARC remotely, you gain:
  • More choice of USB hardware
  • Often better driver compatibility
  • Easier access to high-quality webcams, audio devices, and controllers
2) Robot Skills and vision/audio processing
Vision skills
With ARC onboard:
  • Camera processing happens locally on the robot
  • Less WiFi bandwidth use for live vision workflows
  • Lower latency between camera input and robot response
This can be a real advantage for:
  • Face tracking
  • Object tracking
  • Local autonomous navigation vision
  • Camera-triggered behaviors
However, on a Pi 5 Windows on ARM setup:
  • CPU/GPU performance may be lower than a good laptop
  • Some vision-heavy tasks may run slower
  • Some third-party computer vision dependencies may be less ideal on ARM
With ARC remote on a laptop:
  • Vision skills may run faster and smoother
  • Easier to use more powerful CPUs and GPUs
  • Better overall experience for tuning image processing
Audio skills
With ARC onboard:
  • Microphones plugged into the Pi are local
  • Speech recognition and TTS coordination can be self-contained
  • No network trip just to hear the microphone audio source
With ARC remote:
  • Better access to higher-quality USB microphones and audio interfaces
  • Often easier to debug audio input/output devices
Bottom line for skills
Onboard ARC favors autonomy and reduced latency.
Remote ARC favors compute power and peripheral flexibility.
3) Scripting: JavaScript/Python and automation behavior
Scripts in ARC behave the same logically, but the environment changes.
If ARC is onboard
Your JavaScript/Python automation:
  • Runs directly on the robot computer
  • Is not dependent on a remote WiFi session
  • Can continue reacting to local events without network delay
  • Is better for "always-on" robot behaviors
That’s ideal for:
  • Autonomous patrol behavior
  • Sensor reaction loops
  • Local state machines
  • Startup initialization scripts
  • Behavior that must continue even if the operator leaves
If ARC is remote
Scripts still run in ARC, but:
  • They depend on the remote PC staying connected to the controllers
  • Communication with the robot crosses WiFi
  • If WiFi drops, scripts may still be running on the laptop, but physical control updates may be interrupted
What you give up onboard
Mostly nothing in the scripting model itself, but you may lose:
  • Performance headroom for large scripts
  • Some convenience if you like editing/debugging on a bigger laptop
  • Access to peripherals attached only to the remote PC
If you’re writing code, the ARC AI Assistant built into ARC can help edit or rewrite JavaScript/Python right inside the script editor:
4) Network-dependent features when ARC is accessed over WiFi
This is where onboard ARC is often much better for reliability.
If ARC is onboard
Network is mainly for:
  • Remote monitoring
  • Remote UI access
  • Teleop from another device
  • Sending commands to or from other systems
If WiFi goes out:
  • The robot can often keep functioning locally
  • Core scripts and controller interactions remain on the robot
If ARC is remote
WiFi becomes part of the control path:
  • Robot connection depends on network quality
  • Streaming video, telemetry, and commands all compete for bandwidth
  • Dropouts can pause or degrade control
What breaks or changes remotely
If ARC is on the laptop and the laptop connects to the robot over WiFi:
  • Live control becomes sensitive to signal quality
  • Camera feeds can lag or freeze
  • Network discovery and reconnects matter
  • Some "always-on" behaviors can become less dependable
What breaks or changes onboard
If ARC is onboard and you access it remotely:
  • The robot is still autonomous even if your viewing/control connection drops
  • Remote access is just a convenience layer
  • You can still run a headless robot style workflow if desired
What you gain or lose overall
Running ARC onboard the Pi 5
You gain
  • Self-contained robot brain
  • Better resilience to WiFi problems
  • Lower latency between ARC, scripts, and onboard controllers
  • Cleaner architecture for autonomous robots
You may lose
  • Some Windows x86 software compatibility
  • Some USB/peripheral flexibility
  • Potential performance compared to a stronger laptop
  • Ease of development/debugging if you prefer a larger workstation
Running ARC remotely on a laptop
You gain
  • Better PC performance
  • Broader USB device support
  • Easier debugging and development
  • Great for development, testing, and tuning
You may lose
  • Reliability if WiFi is weak
  • Tight control latency
  • Some autonomy if the network drops
For your specific plan: Pi 5 + IoTiny + Arduinos/servo boards
That’s a very reasonable architecture.
If the Pi 5 is running ARC onboard, and the IoTiny/Arduinos/servo boards are physically on the robot, then ARC becomes the central coordinator while the I/O controllers handle the physical interface. That is exactly the kind of layering ARC is designed for.
For many robots, this is the preferred setup:
  • Pi 5 = robot brain
  • IoTiny / Arduino = hardware interface
  • Cameras/mics = local USB devices if needed
  • Remote laptop/phone = optional operator console
Recommendation
If your goal is:
Best autonomy and robot reliability
Go onboard ARC on the Pi 5.
Best development convenience and maximum peripheral compatibility
Go remote ARC on a laptop.
Best of both worlds
Develop remotely on a laptop, then deploy the project to the onboard Pi for final robot operation.
If you want, I can also give you a decision matrix for:
  • Pi 5 onboard ARC
  • laptop remote ARC
  • hybrid setup
and map each one to cameras, microphones, gamepads, serial devices, and Arduino/IoTiny wiring.
That’s a lot of info from Athena. But I think it would also help to get an idea of the type of robot you’re building - and if you have an idea of what you’d want it to do.
Mainly because if it’s a robot that will be navigating with a lidar etc, an onboard pc is required. Lots of the usb peripherals for sensors would require it to be local on the robot.
Let us know a bit more of your plan and that’ll give more context for a shorter answer:)
That’s a great point - the robot’s purpose really changes the answer.
Quick rule of thumb
  • Navigation / autonomy / onboard sensing:
    ARC on the robot is usually the better choice, and in some cases it’s required.
  • Teleop / testing / development / camera tuning:
    ARC on a laptop is often more convenient.
Why robot type matters
If you’re building something like:
  • lidar-based navigation
  • depth camera / stereo vision
  • multiple USB sensors
  • onboard microphones
  • local AI / vision processing
  • ROS-like always-on behavior
then an onboard computer makes a lot of sense because the hardware needs to be physically close to the robot and not depend on WiFi for every sensor update.
If it’s more like:
  • a remote-controlled rover
  • a demo robot
  • a robot you’ll develop and tune from a desktop
  • a robot with just a few basic onboard controllers
then running ARC on a laptop and connecting over WiFi can be simpler and more comfortable.
In your case
Since you mentioned:
  • IoTiny
  • Arduinos / servo boards
  • onboard hardware connections
that suggests you’re already thinking in the right direction for a robot-centric setup. If you also plan to add things like:
  • lidar
  • USB camera(s)
  • mic / speech input
  • navigation sensors
then I’d lean toward ARC running onboard the Pi 5, with the controllers and sensors physically on the robot.
Best next step
Tell us a little more about:
  1. What kind of robot it is
    • rover?
    • humanoid?
    • arm?
    • indoor nav bot?
  2. What you want it to do
    • drive around autonomously?
    • follow faces?
    • map rooms?
    • respond to voice?
    • use joystick control?
  3. What sensors/peripherals you plan to use
    • lidar
    • camera
    • microphone
    • IMU
    • ultrasonic
    • encoders
    • Bluetooth devices
    • USB gamepad
With that, I can give you a much shorter and more specific recommendation for onboard vs remote ARC.
