On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
ARC Online Help
ARC Online Help
We have been building an online help with video tutorials for ARC. If you have any suggestions or questions for tutorials, let us know.
You can find the online manual under the EZ-Builder Menu Option or by clicking Here
Enjoy!
#26
@Andy1939 said:
"Thing is I cannot right click and get admin as an option cuz it is not an application but the windows installation file. "
If you open Explorer as Admin you should be able to then run Windows Installer files from within that explorer session.
Or if that doesn't work then this absolutely will:
Right click on Command Prompt, Run as administrator
Then, the command window, type:
msiexec /i "YourMsi.msi"
replacing "YourMSI.msi" with the actual file name. Keep the quotes if there are spaces in the file name, and don't forget to include the path to the file.
Or, if this is your personal computer, and you have good Anti-Virus software, you can just turn off User Access Control and Windows will stop differentiating between running as admin vs running as user. Rich and I differ in our recommendation here. Given that you didn't know how to run or search for how to run an MSI as admin, you are probably safer leaving UAC on as it protects you from mistakes...
eek I fixed it by downloading with IE instead of Google Chrome. Go figure..TY all for help!
BUT..... now I get an error every time I try to load a project.
Duplicate headers received from server
Less The response from the server contained duplicate headers. This problem is generally the result of a misconfigured website or proxy. Only the website or proxy administrator can fix this issue. Error code: ERR_RESPONSE_HEADERS_MULTIPLE_CONTENT_DISPOSITION
Do I have to get the robot kit b4 all this works w/o errors? Kinda pricey test.
..or something similar depending on the file I try to load. I will uninstall and try again.
Re-install did not help. So now what?:) eek
#28
:D I ordered my robot and look for a video soon. TY all for help. Wondering how deep the snow is up there:)
#29
Just checking on you Andy1939. There was a problem with a recent update. Everyone was getting that error. A newer version is out now. Be sure to get it from the downloads page.;)
#30
confused I tried to download and got this:
Now you need to go to Windows Update and update your dotnet version.
#32
I did that and now I'm back to unable to install even using EI. Your all gonna hate me. Typing more so I can post. The quick brown fox jumped over the....
