Openai Text To Speech icon Openai Text To Speech — Convert text to dynamic, real-time speech with nine expressive OpenAI voices-natural, varied, accessible robot communication. Try it →
ARC Revolution Error When Downloading A Robot
Hello,
So I am trying to sync my library so I can download some 3D printable robots but I am getting this error:
Downloading library index... 12 EZ-Bit identities downloaded Comparing against your library... Download 12 EZ-Bits... (This may take a while)
1 of 12) Downloading JD Biped Body by DJ Sures (2,292,276 Bytes) Error downloading from EZ-Cloud: The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter https://tempuri.org/:GetEZBitResponse. The InnerException message was 'There was an error deserializing the object of type EZ_Builder.com.ezrobot.www.bits.GetEZBitResponseBody. The maximum array length quota (16384) has been exceeded while reading XML data. This quota may be increased by changing the MaxArrayLength property on the XmlDictionaryReaderQuotas object used when creating the XML reader. Line 4, position 191334.'. Please see InnerException for more details.
#17
I am unable to reproduce these errors... Does anyone know what their windows version details who are experiencing errors?
  • Windows 7 or 8?
  • Windows 64 or 32?
  • Is everyone who is receiving an error getting the same warning about "MaxArraySize" ?
United Arab Emr
#18
Downloaded all and 3D design is operational .
Using Mac , VMware , .net 4.5 , windows 7x64 .
Smooth , direct , takes sometime with downloading compared to 2 MB , .....No errors.
This is what i get every time i try
#20
I got the files on my Desktop. Win7 Home Premium 64bit. Not on my laptop Win7 Pro (It has the 32 version but should have 64. I'm probably going to put 8 on it now that I notice my 7Pro is only 32bit). So Win7HomePremium64 OK. Win7Pro32 no go. (Same max array size error btw)
I think my school laptop may also only be 32bit. Maybe that's the real problem?
Hope this helps.
#21
I am using Win8 (64bits) and everything works just fine... I have been able to download the whole library without any problem.
I think it is the first real advantage I see in Win8 over win7 since I have installed it:D
#22
Windows 8 32 bit Pro - Downloaded OK after numerous Timeout errors.
Windows 7 Ultimate 32 bit - Error (max array)
Windows 7 Enterprise 64 bit - Error (max array)
Windows XP Pro 32 bit - Error (max array)
#23
It is working for me now! I installed .NET Framework 4.5 the newest one from Microsoft and it works now! Everyone try doing the same first and see if that fixes the issue.
do you have a link to dl the framework 4.5 file
