Downloaded new ARC and now issues with my roomba commands. stress
RobMcc
— Edited
Websocket Server
— WebSocket server for ARC: accepts clients, stores messages, runs per-message scripts, tracks connection status, supports debug, needs Windows admin
Going to need more info than that dude.
What are the issues? What controls? Post the project file?
If you are talking about the script (that I just noticed as I closed the image) then you need to check the syntax of the script. EZ-Script syntax changed a few updates ago and it looks like you have text that is not enclosed in quotes (which is now a requirement for all text) on line 12. The debug of the script should tell you everything you need to know on that one.
A few months ago the EZ-Script was changed to require proper use of strings. This means surrounding commands in quotes "like this"
Thats what I needed. Thanks DJ been a while since I got a chance to sit down with this again. And just moved everything to my new pc. Ok a few mods to my script all good.
Don't forget to mark as answered if it has been
Thanks Guys.
