EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
As the message states, verify the file exists and that you can access it. Otherwise, re-download a new file. If the problem persists, consult a computer expert to ensure you do not have any viruses and your computer is in working order. Have fun!
Thanks Dj, I moved the setup to another disk and try to install. setup was installed successfully.
