Live Stream Broadcast icon Live Stream Broadcast — Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access. Try it →
Hi Keith - the ARC software was originally built in C++ and eventually ported to C#. With Microsoft's recent move to opensource .Net, this helps for portability between devices. The ARC Mobile and ARC PC are able to share essential libraries for the EZ-Script Compiler and a variety of other features.
The EZ-SDK is the base of all EZ-Robot Software. The EZ-SDK contains a few third party libraries, such as ffmpeg and a modified AForge.Net. For the audio MP3 decoding, the NAudio library is used.
OpenCV is not used - but you can use it, such as the EZ-Face can be used as an example - which uses OpenCV.
