i did averthing like in the video.but i get an error,dont know what it is. need help.what does this mean?
— Edited
6 Participants
HMC5883 Compass
— Reads HMC5883 3-axis compass via I2C and updates EZ-Script variables on demand; polled control offers periodic heading data, for connected sensors.
The library link is in the plugin description, with instructions in video. If this discussion is regarding Cognitive Vision, all relevant installation details, including library links and step-by-step instructions can be found here: https://synthiam.com/redirect/legacy?table=plugin&id=180
Uninstall your previous libraries if they're giving you an issue
I doubt this works with Windows 7, as it's been discontinued by Microsoft
dj
am on win8 .ok i uninstall all.
nope doesn work.i uninstall all and redowload. typical for belgium nothing works here. thanks guys,
I'm getting the same application error and close message as Nomad with the latest plugin for Cogitative Vision. I have Windows 10, latest versions of everything and the x86 redistributable.
And I have the same values as Nomad when running the cmd command to get the version, mine come back as 14.0.24212 and also like Nomad I don't have that 3rd option for the "debug" version. I did download from the link in the instructions and installed without known errors. I did follow the direction.
The Cognitive Emotion work fine. And right before the application error the Cognitive Vision window will load the image from the camera and say "working..." then the error pops up.
Any idea what else I can check?
@DJ,
I debugged the exception and the exception is:
we can't see the exception because is inside multiple (nested) async calls, and is not captured, and the result is an application error.
i found the cause.
your plugin code calls the following constructor:
to pass the vision api key, but there is a second constructor:
to pass the endpoint. The default apiRoot (endpoint) is: "https://westus.api.cognitive.microsoft.com/vision/v1.0"
BUT !
Microsoft API keys are geolocated based on user input, and a specific Azure datacenter is assigned.
if the client key is registered for the westus.api.cognitive.microsoft.com endpoint it will work as expected.
mine:
my key only works for: https://westcentralus.api.cognitive.microsoft.com/vision/v1.0
To summarize: The plugin needs to ask for the endpoint url.
mine works for a bit then crashes i checked and I have set it up using the video instructions that were just posted the other day. windows 10 creators update with all patches and mine shows the correct version of the Microsoft Visual C++.
I ran the c++ install from the website instead of downloading then running and now the command line returns version 14.0.24215 like ptp, but it sounds like that may not have mattered. The same error occurs. From ptp's explanation that sounds like it would be expected.
