Intel Realsense D435i icon Intel Realsense D435i — Connect Intel RealSense depth cameras to ARC NMS for depth-based distance detection, point-cloud mapping, video streaming, and navigation telemetry. Try it →
ARC Error At Loading Of Ippsp Libarary?
After update today causing error, ARC starts OK but as soon as I select a project or Add an item (Camera causes the error when selected), I get the following error:
Error Title: Error at loading of ippSP library
Error Comment: No DLLs were found in Waterfall procedure.
After error flashes ARC freezes and then closes
Worked fine prior update.
UPDATE: Problem fixed, Caused by the files in: C:\Windows\SysWOW64 ippcore-6.1.dll ippj-6.1.dll ippjw7-6.1.dll ipps-6.1.dll ippvc-6.1.dll
Removed file's from directory and saved in a folder in case needed later. Now ARC works.
No DLLs were found in the Waterfall procedure
Yes but work until current update. See updated post above (-: Thank You I forgot about that (-:
