Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
ARC Update Corrupted My ARC Software
Install the ARC update, immediate problem with loading previous saved projects, particularly with joystick installed. How do I roll the builder software back to previous version without losing all my projects files? ARC is a bad update if you can,t use the files I was just using yesterday.
#1   — Edited
This reply is totally useless. Please have a live person answer the question above ( yes has question mark, totally childish when communication on a computer). This is not a comment, but a question which needs to be answered.
you can revert: uninstall the ARC beta and download the ARC version.
It was not clear that "arc beta" is a rebranding plus some new changes but is an update in place of the existent ARC same folders etc.
It works similar to the ARC beta you can only have one installed, I know is not practical but hey is free;)
if you have "production" projects I recommend a staging machine to evaluate and try beta releases.
#3   — Edited
Update Here you go: https://synthiam.com/Products/Releases/ARC-Beta-2020-01-24-00-19052
That update resolves issue with reading legacy configuration file for joystick button settings.:) All fixed!
Optional ARC rollback To roll back, Simply uninstall ARC and install ARC:). It’s beta, so your feedback experience is helpful. Thanks! Additional detail here: https://synthiam.com/Products/Releases/ARC-Beta-2020-01-23-02-19052
ps, I removed your email address from the post for your privacy protection
@DJ you missed post #1 you need to do foreach post remove:)
Ha - foreach:);.. email removed!
