Hello All;
Don here, (Dlanod375) -
In the ARC software under the design tab, how do you bring in or create your own files, say for a B9 robot or a R2D2 droid. What type of files are needed, Thanks in advance !
D confused
Soundboard (PC)
— Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate.
Hello All;
D confused
I was under the impression you can only use EZbits to design your own robots... That in itself would make it difficult to design an R2D2 or a B9.... I guess it would be possible if someone would design and upload R2D2 or B9 ezbits...
To answer your question you need to sync to the cloud library then you can create your own design from the bits in the EZBit library...
You can import STL files in to the bit builder, I guess this may be what is being asked?
I'm not at a PC with ARC so can't go over the process however it is pretty much self explanatory in the Bit Builder.
use a software package such as Solid Works, Sketchup, or AutoCAD 123, etc... Design your parts. If you want the parts to be shared for 3D printers, make sure you 3D print test the part so we can verify it.
Save your designs as STL files to be shared with the 3D printing community
Download and Load ARC
Press the My Project tab from the top menu ribbon
Select "Bit Builder" under the EZ-Bits section of the My Project Tab
Follow the instructions on the Bit Builder first menu popup page
If you're not wanting to make a 3D printable part, simply use a photo in the Auto Positioner of your robot instead.
@Don, if your going to 3D print a B9 you gotta post pics! I'd love to see it.
I'm assuming it's going to be a scale model R2-D2 or B9, and not lifesize!
Moebius Models just released a 1:6 scale B9; you might be able to use one of those and animate it...
Got a Moebius Model and it's great. However I'm using all my spare time to animate my full size B9 I'm building.
Hey All; Thanks for the comments. DJ nailed what I was looking for
To answer some comments - no - not scaled down - full scale, FYI B9 robot is 6'5" tall.
Not printing it in 3D.
I'll get some pix's posted in the near future.
Thanks to all. D
Wow! 6'5" tall.... You and Dave need to talk.... Yes, definitely keep us updated....
