Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Ireland
Resolved Resolved by Rich!
Adc Disconnecting Ezb
would appreciate assistance please included a short set of instructions that reads a potentiometer on a motor shaft and then moves a motor forward & reverse
but for some reason it crashes my EZB after a few moves
script :one set(d22, on) ADC_Wait(ADC7, lower, 120) set(d22, off) sleep(900) set(d23, on) ADC_Wait(ADC7, higher, 180) set(d23, off) sleep(900) goto(one)
Debug report 27/10/2014 22:23 - Attempting connection on 192.168.1.1:23 27/10/2014 22:23 - Connected to 192.168.1.1:23 27/10/2014 22:23 - EZ-B reports EZ-B v4 OS 27/10/2014 22:23 - Welcome to EZ-B v4 Beta! 27/10/2014 22:23 - EZ-B v4 ID: 46-54-0-0-47-255-58-58-56-38-37-38 27/10/2014 22:23 - Connected 27/10/2014 22:23 - Disconnected 27/10/2014 22:23 - Attempting connection on 192.168.1.1:23 27/10/2014 22:23 - Connected to 192.168.1.1:23 27/10/2014 22:23 - EZ-B reports EZ-B v4 OS 27/10/2014 22:23 - Welcome to EZ-B v4 Beta! 27/10/2014 22:23 - EZ-B v4 ID: 46-54-0-0-47-255-58-58-56-38-37-38 27/10/2014 22:23 - Connected 27/10/2014 22:23 - Setting battery monitor voltage: 6.6 27/10/2014 22:23 - Setting battery protection: True 27/10/2014 22:23 - Setting i2c rate: 100000 27/10/2014 22:24 - Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.EZB.(Int32 , Byte[] ) 27/10/2014 22:24 - BbytesToExpect: 2 27/10/2014 22:24 - ? Received: 27/10/2014 22:24 - Disconnected
Ireland
Richard It has to be something along that line as with only the ADC port connected it will crash out will do some further tests when I get home later thanks
Ireland
Thanks to all did a full re install of EZ Builder seems to have resolved issue well it has worked for more than a few minutes so fingers crossed
At times like this I need a resolved by " all " option
Ireland
@Richard @Robot -Doc @Rich So who do I give the credit for resolving and assisting my question had to draw from hat for this one Thanks to all as usuall for quick response
:P:P:P
