Wowwee MIP V2 icon Wowwee MIP V2 — UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200 Try it →
Resolved Resolved by Rich!
Adc To Move Jaw New Software
Hello, I had a working JAW/mouth working with older software. I upgrade to the lastest software and can't figure out how to sync the jaw using a analog to digital from my PC to the power amp that goes to the ADC0. I can't figure out how to make it work using the new software.
This is what I had using the older software for the jaw sync...If (ADC(ADC0) > 1) servo(d4,48) sleep(10) release(d4) endif
Any help would be nice.
Thanks, Mike
#25
Hi Mike,
I'm just wondering if you have upgraded to the most recent ARC?
Deleting a servo has now been fixed in the newest version, I just verified it.
To keep the servo positions you've initially generated you will have to select that pre-made frame and then click new frame, name it, and then select it the new frame on the list of frames. This will keep the servo positions you made in the last frame and allow you to change them as needed for your action.
Just in case you haven't come across it yet, in order to see all the port numbers use the "Port Edit Mode" check box.
For every event you'd like to execute you can either generate an new "Action" or you can execute a script with multiple frames or actions in it.
An alternate way would be to use a script inside an Action, just click on the "edit script" button near the top right of the action screen.
#26
I download the newer ez_builder and it seems better. I want to thank everybody for your input and guildandce. I am gvoing to be away for my project for a couple of days.
Thanks everyone, as always v/r Mike
