ZAMA Emotion Model icon ZAMA Emotion Model — Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors. Try it →
Adding Wifi To One Of My Existing Ez-b's
Adding Wifi To One Of My Existing Ez-B's
Wednesday, 20 February 2013
Good Morning EZ-B Robot Builders !
How much Code would be required to add WiFi to one of my existing EZ-B's ?
I still want to Maintain ALL the ARC Features, other than BlueTooth !
A most reliable friend guided me to the following Modules :
Roving Networks' RN-XV Wi-Fi Module 30025, https://solarbotics.com/product/30025/
SparkFun XBee Explorer Regulated 50828, https://solarbotics.com/product/50828/
Thank You All For The Consulting Services,
[email protected], 602-246-1246(H)
Thursday, 21 February 2013
Good Morning Robot-Doc & Thank You For The elechouse WiFi Link !
 The Elechouse Photo showing it connected to an Arduino suggests we simply unplug the Bluetooth transceiver from the EZ-B, and replace it with the TLG10UA03 embedded Uart-Wifi modules supplied by elechouse.
 Is it really Pin-For-Pin Compatible ?
 Looks GREAT ! Has anyone published the EZ-B Script or Code for it ?
Thank You, [email protected]
No code is needed works like the bluetooth module
I am designing WIFI board to have both wireless and wired network
Hi Doug, The WiFi board is not a pin for pin lineup with the existing header on the EZ-B. Some jumper wires will be needed to connect the Tx, Rx, Vcc, and Gnd leads.
I dont think any board ,like WIFI usb,or bluetooth is
BEST idea is make adapter board,like the way DJ made for the older EZB with bluetooth
The class 1 BlueSMiRF from Sparkfun has the correct pin for pin wiring when the header is soldered to the bluetooth and plugs directly into the EZ-B header.
I have been working on wifi for a long time and got it to work but super slow,i am waiting for @ROBOTMAKER to do some magic :D
I hope soon to work,mostly very good at wifi and wired,PITTOM what board do you have,
I love testing all types,one right getting to start on is adding network wired RJ45 to have both wired and wireless with auto switching,same idea going to use for bluetooth
