Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
Adding pre-programmed Dance to Robo-Scratch
Adding Pre-Programmed Dance To Robo-Scratch
Hi there, I have spent half the day researching and toying with an issue with a program for the JD Humanoid.  I am pretty sure it's user error. :/  I am trying to add the pre-programmed dance for the song Lose Yourself to Dance using Robo-Scratch.  I have added both the sound and sound wait function.  The song will play, but the movements as seen when I click play in the home workspace are not working.  I can see from the Java script view that the instructions say "ignore script".  I have watched a few tutorials and it looks like it should work by just adding the sound.  Any ideas would be super helpful. Is there a way to add the pre-programmed movements to the Lose Yourself to Dance using Robo-Scratch?
JD Humanoid by EZ-Robot
Hello @joannadillman I was curious if you've tried placing sleep delays in your Robo-scratch program to make sure the action has time to execute and finish before moving to the next part of the program?
The RoboScratch Action has a built-in sleep to make it easier.
Behind the scenes it it adds sleep just like what's selected...
Ideally it'll be easier and way more fun to create the dance like that awesome The Robot Program episode:D
DJ you are a genius!!! Thank you so much for including the info about the soundboard manual.
Glad that helped:)
