Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Resolved Resolved by EzAng!
Adding two speed controls (brush-less) plus two motors for my tank base.
Adding Two Speed Controls (Brush-Less) Plus Two Motors For My Tank Base.
I have two brushless motors and speed controls I would like to add to the EZ robot B v4 and I also purchased two 5 amp controllers as I was told I would need them. Do you have a tutorial for adding what I have described? I will be running two separate batteries one for each motor. I will also have a battery for the EZ-Bv4.  Please let me know if you have any other questions. I read through ALL the documents online and watched most of the videos. I have it all set up and bought a wifi dongle (wish I knew that before I started). I just need to know what to add for the dual motors for the Synthaim software and how to add setup the wiring on the unit.
Thanks, Adam
#10   — Edited
thank Jeremie for help
I have all of that, I just need to know how to connect the speed controls to the boards (I got the EZ Robot ones). "I have two brushless motors and speed controls I would like to add to the EZ robot B v4 and I also purchased two 5 amp controllers as I was told I would need them. I will also have a battery for the EZ-Bv4.
#13   — Edited
good luck with you project
#14   — Edited
@EzAng,
This thread started with:
Then the Op wrote:
Quote:
They are brushless motors, so what you are saying is that there is no way to do that? I am sorry for the newbie questions but I purchased two-speed controls & two brushless motors ($500 so far). Should I just get a RC radio and go that way? Or is there another solution?
your posts are not helping the user.
#15   — Edited
@Bullseye:
Afaik If you have an ESC controller you don't need a 5 amp controller. btw the L298N (controller) the absolute maximum spec is 2 Amps DC continuous, per channel.
as an advice, before you buy, ask questions, and validate the answers.
#16   — Edited
PtP,
I believe Jeremie and I were helping just fine.
Bullseye said "quote"-   I am pretty new to this, so please don't assume I know anything : )"
It seemed to me that as he said  "quote" I am pretty new to this " -  The advice he got form ( I don't know where to buy this stuff) this might be over your head at this time
Bullseye said "quote" -    Or is there another solution?
I offered a easier solution for a beginner, I used brushless motors - I made a video of my tank base robot, it worked just fire
the L298N Dual H-Bridge and Pulse Width Modulation (PWM) control) works fine, I did it as I stated.
Specification: Name: Dual H bridge motor driver module Working mode: H bridge driver (dual) Main control chip: L298N Logic voltage: 5 v The driving voltage: 5 v - 35 v Logic current : 0mA-36mA Drive current: 2 a (MAX single bridge) Storage temperature: - 20 C to + 135 C Max power: 25 w Weight: 30 g Size: 43 * 43 * 27 mm
L298N motor controller board module, ideal for Arduino smart car power UNO MEGA R3 Mega2560 (I used the EZB4)
I even used it with the servo city The Prowler kit: it works fine
The Prowler offers a great starting platform for any robotics project. With 313rpm ball-bearing, metal geared, Premium Planetary Gear Motors and high-traction 5.4" off-road tires, this is one powerful platform!
As Jeremie Said, who works for Synthiam with DJ -  "quote" - An H-bridge can be hooked up to a Robot controller just as EzAng mentioned.
PTP "quote" your posts are not helping the user."
I offered a working solution - think this over - You offered no solution, just criticism.
We tried our best.
thank you  EzAng
