Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
Portugal
Adding values to variable
Adding Values To Variable
setVar(CLeft,0);
def loop():
  if getVar("$RoombaLightBumperCenterLeft")==1:
     Navigation.SetNavigationStatusToPause();
     print "Bumper Center Left";
     setVar(CLeft)+=1;
     sleep(5);
  if getVar(CLeft)== 2:
       Movement.left(100, 1500);
       setVar(CLeft) == 0;
sleep(2)
 else:
     Navigation.SetNavigationStatusToNavigating();
     time.sleep(1);
  loop();
loop();
I dont get this python. I am trying to add 1 to the variable "CLeft" but my code does not work. Anyone?
Roomba by iRobot
Synthiam ARCx turns iRobot Roomba into a drivable robot with scripts, sensors, browser control, and AI-ready robotics skills.
Controller Dependant
Servos ✕
ADC ✕
Digital ✕
Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN.
Does your code require global variables for cleft?
you are using the getvar correctly for the roomba, but not for anything else
Portugal
I dont think it needs to be global. I get this output in the console: Start can't assign to function call Done (00:00:00.0316139)
England
#3   — Edited
setVar(CLeft,0)
def loop():
     setVar(CLeft)+=1
     sleep(5)
     setVar(CLeft) = 0
     sleep(2)
  else:
     sleep(1)
loop()
loop()
I have no way to test your code (no roomba) but the indentation is totally incorrect. Now this may be because of the way you uploaded the code. Also python does not use the semi-colons at the end of each line like C does (unless ARC has it's own interpretation) and you use sleep() and time.sleep(), would you have to import time to use these? If you alter the value of setVar() inside the function you may have to declare it as global inside the function. I have altered the indentation and removed the semi-colons so this may help someone who can test the code. NB from memory ARC uses python2.
Portugal
Hi Skidroe, the indentation is correct, it must have gotten that way when I did the 'past'. I will try it tomorrow. Thanks.
Again you’re using setvar incorrectly. The incorrect syntax.
If cleft does not need to be global, don’t use setvar and use a locall variable
#6   — Edited
Read python manual: https://synthiam.com/Support/python-api/python-overview
BUT, again i don't think your code requires cLeft to be a global variable. So don't bother using either setVar or getVar at all. Just use a regular python variable. setVar and getVar are for global variables that you wish to share across ARC environment.
Since you keep mentioning it, look at both setVar and getVar
England
proteusy,  looks like the sleep() command uses milliseconds so first sleep should probably be sleep(5000)
DJ,  this code is an example taken from the ARC support documentation on python navigation
// Pause navigating if the ping sensor detects an object less than 100 distance and continue if greater
if (Ping.get(d0, d0) < 100)
else
Line 1:  The REM statement in python is the hash sign # not the double forward slash as in c/java
Line 2:   Any if command  should be terminated with a colon.       ie    if(test):
Line 3 and 5 : Each of these lines terminate with a semicolon ? This is not python syntax.
Line 4:    Same as line 2, should terminate with a colon     ie   else:
Just trying to clarify. Is ARC using it's own python variant or is the example incorrect?
Portugal
import time
ab = 0
while(True):
     ab += 1;
     print ab
  if ab == 2:
     Movement.Left(10,4000);
     Movement.Stop();
     ab = 0;
     print ab
  else:
     time.sleep(1);
Got it working with the while(true) instead of def (loop). I use the getVar becouse the roomba variables are global. I dont understand the semicolon usage in this python. The Movement.Left does not stop the movement after 4000ms, i must use the Movement.Stop().
