Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
Some are supported natively, check the tutorials and hardware sections to see what and how.
Others do require scripts. Scripting is done in EZ-Script, which is part of ARC. It is as easy to use as it sounds. There are many topics here which cover different functions and explain what's what.
Thanks
Wher edo you download the users manual.
The links I have found so far on the site sned me to movies
The movies are tutorials. The forum is a live user guide. ez script manual is in ez script dialogues.
Searching the forum usually answers any questions you may have.
For a more in depth view on EZ-Script I recommend reading through and following the An Introduction To Scripting post in the EZ-Script section. In it I am explaining the functions and methods used along with giving example scripts. I may be biased since I am writing it but it is a good place to start:).
And anything else, just ask the community. We are a good bunch who pride ourselves on helping each other.
It seems i am not the only one who doesnt use spell check ,or good grammar
@slim. Welcome to the forum!
Sometimes my fingers get a head of my brain
@ robot maker , you probably have the same laptop without a caps light. Lol
@Slim the common sensors like sonar , IR distance , switches , sonar with scanning radar ext are easy to add in. It can do practically everything you can imagine. ADC ports are for reading signals that vary from 0 to 5 volts and digitals are outputs for servos , LEDs , motor controllers or switching transistors.
