Servo Summary icon Servo Summary — All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit. Try it →
Resolved Resolved by Athena!
Adventure Bot Improvement
so the adventure bot is for playing,i notest the batt wire is dragging on, the floor withs is not good.here simpel solution.put the wire on top. and like cars have a wing,adventure has one to now.
as you can see no wire below,comes out ontop.
DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
Hi @Nomad,
We found this too when playing with different designs for the Adventurebot so we added an extra cube at the back to raise him up a little more. I think we just missed the extra cube in the Adventurebot's assembly instructions.
that looks also good.will it not tip over?
Nope, the center of gravity is still pretty low.
I was wondering why he came with an extra cube. I thought it was just a packaging error.
jeremie
good thinking.
alan
you are so lucky haha
@Jeremie,
The front end in your picture (and in about half the pictures of AdventureBot) is also different from the assembly instructions. The wheels are lower and set back further. I can't quite tell looking at the various pictures how all the cubes are oriented. When I tried to duplicate it, the wheels sat further from the body, and the tail was flat on the floor, rather than just dragging its tip.
