Script Collection icon Script Collection — Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands. Try it →
Hey, I am planning on making an airsoft robot like one called "Robotic weapon"
obviously much more smaller simple and cheaper. I just had 2 questions:
can the EZ-B v3 control these DC motors www.robotmarketplace.com/products/BP396505-21.html and if it can how?
and question number 2, can the EZ-B control linear actuators like the firgelli L12?
please let me know if one of does is not possible with what other platform I might be able to do it.
cool,
if I a using 2 of the dewal motors that I put before do you think a 14rc sabertooth will do the job?
Not the RC sabertooth, you need the microcontroller version... Yes, sabertooths can handle up to 30V and 100+amps depending on the model you buy... You need to be more concerned about the amps the motors draw wore than their voltage they use... The Sabertooth is controlled via serial commands or the sabertooth Movement Panel in ARC software... I would consider geared motors instead of the Dewalts you listed.. servo City also sells geared motors... Something around a 100 or so RPM would work well...
