HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
Also About Using H-bridges
Also About Using H-Bridges
if you have a 4 wire h bridge can use a simple circuit to convert it to a 2 wire pwm and control (fwd,rev) 4 wire h-bridge is full bridge using 4 mosfets,2 wire bridge is a half bridge using 2 mosfets,if you need more power some chips like l298 can be put in parallel ,and same with mosfets need any help on using any kind of h-bridge designs i can help you
Hi robotmaker,
I would like to use the EZ-B to control the Ultimate Wall-e, but using its H-bridge. On the attached pic it looks like the H-bridge has 8 mosfets???
Would it be possible to even use the EZ-B with this type of H-bridge? It looks like each motor has 5 wires, yellow grey grey + red black, green grey grey + red black ?
I found this circuit diagram on the web that is supposed to drive two motors & may be similar to above config?
Please advise if you have the time.
Thank you,
Manuel
yes can work with 4 digital lines,not really that great,they not using mosfets,there are simple circuit to add to it to make a 2 wire bridge mosfet bridge would work better,they only using it likes 4 wires,rest is a tach or speed switch
