TCP Script Server Raw icon TCP Script Server Raw — TCP server for ARC accepting EZ-Script, JavaScript or Python commands, letting controllers send commands and receive line-terminated responses Try it →
Alternative Mp3 Trigger Sound Modules
I started testing some alternative MP3 Sound Modules, my goal to get similar functions but at 50% less than the cost of MP3 Trigger ($50 + s/h). This could help people with low budget that want to get into robotics or just wanted to build a low cost robot. I choose these two modules in theory from reading their data sheet should work with EZ-B thru very simple sendserial command already built into ARC:
This MP3 module im testing and is working very well with EZ-B, it supports 40 MP3 files, 6 outputs:
40MP3 Module
Specification
This MP3 module supports 199 MP3 files and 8 outputs but I can't get it to work because it required baud rate of 4800 which ARC doesn't support but i would like to have it working because it supports 199 MP3 files and have better features than the above module:
199MP3 Module
Specification
However both modules needs an audio amplifier but for the price you can't beat for small to large robot projects that don't need a lot of sound files.
I have already got it working well with my Wall-E project, there is just one problem because the volume reset once power is disconnected so i found a way around that by using a init script at connection to change to max volume and a start up sound. All costs less than half price of MP3 Trigger:).
Here is a rough wired pic using Wall-E own speaker, MP3 module, and a dual 3W amplifier. I will post more details soon but still i would like to be able to use the 199 mp3 module, nice thing is both module output stereo sound and you are not limited to small speakers, just use bigger amp for bigger speakers and blue color matching EZ-B board:)
More details on wiring and custom scripting coming soon...might make a demo video if i have some free time.
#65
I'm looking for one too. Just doing a little snooping on Ebay and seen this. Less then 6 bucks ... WOOT WOOT ... will it work?
https://www.ebay.com/itm/MP3-Voice-module-U-disk-audio-player-SD-card-voice-module-WTV020-SD-16P-/160806790230?pt=LH_DefaultDomain_0&hash=item2570d4e456
Heres more info if needed: https://www.elechouse.com/elechouse/images/product/MP3%20Sound%20Mini%20SD%20Card%20Module/MP3%20Mini%20SD%20Card%20Module.pdf
Please send a link if possible to the one you are all talking about.
Herr
#66
@jstarne1...how many do you need? I have 5 new units that I don't need right now, same price + s/h? Let me know. Thanks
#67
Hey Louis T - did you ever get that 199mp3 board to work? Also, if you had an extra one of the 40mp3 boards I would really like to buy it. I kinda ruined mine.....soldering iron and a lot of curse words....Any way, if you could help a bot out that would be great! Thanks, Bret
#68
I found another module on MDFLY that will use up to 99 mp3s and uses the TF card (up to 32g). It is smaller and uses less Voltage. It is only $20 so I bought one. It works just like the one mentioned above. Here is the link SD/TF Card
#69
That's nice. I got 5 of those 40s board if anyone needs one. I never got the chance to work on the 199MP3 board, think i saw that 99 one before but i didn't go for that because it was over $30 at the time, i think they have just lowered their price. The other reason i use the 40MP3 board is because it can run off 5V input so you don't need an extra step-down regulator, the 99MP3 board use 3.3VDC input so you need to care of that. Good find though! Let me know how that work out.
#70
I'll take one. Can I paypal you the money? How much?
#71
Yes I believe i got it for $16.95 + s/h, sure send me an email thru aprohobbies.com
#72
Louis t I would love to get a couple of those. Are they on the aprohobbies website? Thanks
