Alternative To Speech Recognition As A Fail Safe Method
I am looking to use JD as an assistant in a comedy show I am doing for children. I know the children can create a lot of noise. Therefore I need to find the best fallback if speech recognition does not work. Is a keyboard shortcut the best alternative?
Oh smart idea! Never thought of glyphs. That’s a good one. You can also do qr codes! I think there’s a the robot program episode on that as well.
Hi, Thank you I think that the key control would be the best . As the glyphs and QR codes maybe an issue if I am working in a low light environment. I also have a MYO band. could I use it?
The myo could be used, but it’s not a very reliable input device. The actions aren’t always detected by the myo hardware. I find it inconvenient for detecting actions.
The only thing I like about it is controlling servos with the accelerometer.
