XV11 LIDAR icon XV11 LIDAR — Real-time 2D mapping from Neato XV-11 360° LIDAR via GetSurreal controller; exports $LIDARDistance/$LIDARIntensity, configurable angles, color, zoom. Try it →
An Introduction To Scripting
All script examples are on the EZ-Cloud for download and updated after each additional post Download Now
Index Part 1 - You are here Part 2 - Page 1 Post #6 Part 3 - Page 1 Post #8 Part 4 - Page 2 Post #6 Part 5 - Page 2 Post #9 Part 6 - Page 3 Post #5 Part 7 - Page 4 Post #3
I have some time on my hands and nobody seems to be asking questions at the moment so I though I'd just write up a nice and simple introduction in to EZ-Script. I may write more in the future but we will see how received this is first.
EZ-Script is a powerful scripting language with a wide variety of commands. The command user manual is displayed to the right of the EZ-Script environment within ARC and a PDF version of the manual is maintained and downloadable from here.
Scripting needn't be difficult. A lot of people see lines and lines of code in the examples and are overcome by this however the number one rule in scripting, at least for me is to think logically, dumb it down and tackle one piece at a time.
I will go through how to write an example script in a logical manner and have a working script as an end result. In this example we will define variables, look at If statements, control devices attached to the EZB and read data from the EZB.
First we need to work out the algorithm for the task we want to achieve. Think of it as you think of a recipe when making a meal. It's a sequence of events in a specific order to achieve the overall result.
This example we will make our robot scared of contact and run away when anyone or anything comes in close proximity. In order to achieve this there are some hardware requirements; Drive motors or servos Proximity detector
For this example we will assume the robot is driven by DC motors via a 4 wire HBridge, with a correctly set-up HBridge Movement Panel in ARC and for proximity detection a low range infra red sensor connected via the ADC port ADC0.
So first, we need to think about what it is we are doing. We need to know if anything is coming in close proximity to the robot so we need to read the information supplied to the EZB via the infra red detector.
EZ-Script has a neat command for this, the GetADC command;
Quote:
GetADC( Port ) Returns the ADC value of the specified port Example: GetADC(adc0)
So the first part of our code would be to get that ADC value and store it in a variable for ease of use. We will call this variable $proxsense. Notice the $ symbol preceding the variable name, this is required for all variables.
$proxsense = GetADC(adc0)
The value of ADC0 is now stored as the variable $proxsense.
So now that we have the value of the proximity sensor we need to use it. We need to know if someone or something is in close proximity to the robot, so we need to compare the value of ADC0 to a known close proximity ADC value. This varies on different hardware and testing may be required for accurate results. For the benefit of this example we will assume an ADC value of 50 or less is close proximity.
So let's add this as another variable;
$proxclose = 50
Easy right? It doesn't get much harder either:)
So we have the current sensed proximity value and the minimum allowed proximity value stored as variables. We want to be able to do something if the sensed proximity is more than the maximum allowed proximity. If you read that sentence you may be able to work out the next command we need to look at...
The IF command;
Quote:
If (Value Condition Value ) IF condition can support multiple comparisons and functions. Condition tree must be closed with an ENDIF See the Functions section of this document. Condition can be =, , =, , AND, OR Example: If (GetDigital(D0) = 1) Print("One") EndIf Example: If ($Day = 2 AND $Hour = 3) Print("Hello") EndIf
So let's look at this logically, we have the sensed proximity, the maximum allowed proximity and want to see if one is higher than the other.
IF($proxsense > $proxclose)
ENDIF
This will look at $proxsense, check it against $proxclose and if it is greater than (>) $proxclose it will run the next commands. If not then it will jump down to the endif command. All if statements must be finished by an endif command.
So the code so far should look like this;
$proxclose = 50
ENDIF
While the code will compare the values it still doesn't do anything. Nothing has been defined in the if statement. But what we have achieved is for the script to now be able to find out if someone, or something is in close proximity to the robot.
So now we want to have the robot do something if the statement is true. The next question is what do we want it to do if someone or something is too close? We want it to run away, all scared and full of panic.
So how do we do that?
First we decide if we want the robot to just reverse away, as if running backwards. We could, but do you run backwards? No, you turn and run. So we will make the robot turn 180 degrees (roughly) and run away.
How do we do this in EZ-Script? Easily!..
EZ-Script has all five of the Movement Panel commands. Forward, Reverse, Stop, Left and Right;
Quote:
Forward( [speed], [milliSeconds] ) Using a Movement Panel Control, this will start your robot in the Forward direction. Optionally, you can provide the speed and/or number of milliseconds to move. You will require at least one Movement Panel to be configured within the project. This function will control that movement panel. Speed is a number between 0 and 255 Example: Forward() Example: Forward(200) Example: Forward(255, 5000)
Reverse( [speed], [milliSeconds] ) Using a Movement Panel Control, this will start your robot in the Reverse direction. Optionally, you can provide the speed and/or number of milliseconds to move. You will require at least one Movement Panel to be conf igured within the project. This func tion will control that movement panel. Speed is a number between 0 and 255 Example: Reverse() Example: Reverse(200) Example: Reverse(255, 5000)
Stop() Using Movement Panel Control, this will stop your robot. You will require at least one Movement Panel to be configured within the project. This function will control a movement panel. Example: Stop()
Left( [speed], [milliSeconds] ) Using a Movement Panel Control, this will turn your robot left. You will require at least one Movement Panel to be configured within the project. This function will control that movement panel. Optionally, you can specify the speed and/or number of milliseconds to turn. Speed is a number between 0 and 255 Example #1: Left() Example #2: Left(200) Example #2: Left(200, 5000)
Right( [speed], [milliSeconds] ) Using a Movement Panel Control, this will turn your robot right. You will require at least one Movement Panel to be configured within the project. This function will control that movement panel. Optionally, you can specify the speed and/or number of milliseconds to turn. Speed is a number between 0 and 255 Example #1: Right() Example #2: Right(200) Example #2: Right(200, 5000)
Direction of turn doesn't matter so either the left or the right command would be suitable. For the purpose of this example we will turn left. To turn 180 degrees is not an exact science since the robot has no means of knowing it's direction. Turning is time based and this must be calculated by timing your robot for how long it takes to rotate 180 degrees. For the purpose of this script we will assume the robot rotates 1 degree in 0.1 milliseconds or 180 degrees in 1800 milliseconds.
LEFT(255,1800)
Now that the robot has done an about turn and is facing away from the scary thing in front of it it needs to run forwards to get away. So a forward command is issued. We will make it run away for 5 seconds.
FORWARD(255,5000)
And that's it. As simple as that. So the code so far should look like;
LEFT(255,1800)
FORWARD(255,5000)
Now let's put it all together. We can do this a couple of ways. One way would be to put the left and forward commands inside the if statement, and if you have a basic script there is nothing wrong with that at all but I want to show you the Label, Goto and Return commands too;
Quote:
:Label Defines a label for a GOTO() command Example: :My_Label
Goto( label ) Goto a specific :Label location Example: Goto(My_Label)
Return() Return from a Goto() If you jump to a position of code with a Goto(), the Return statement will allow you to return back to that piece of code following the last Goto() If you attempt to Return() with an empty stack, nothing will happen. The script will ignore the Return() statement. Example: Return()
These commands can be used to set up what I like to call Sub Routines. A small piece of code which can be called up from many places within the code. These are great if your script is long and manages many different tasks that all may require the same sub routine.
So we set up the "runaway" sub routine;
:runaway
LEFT(255,1800)
FORWARD(255,5000)
RETURN()
And then we add in the Goto to the first part of the code we wrote;
$proxclose = 50
  GOTO(runaway)
ENDIF
And when we put it all together;
$proxclose = 50
IF($proxsense < $proxclose)
  GOTO(runaway)
ENDIF
:runaway
LEFT(255,1800)
FORWARD(255,5000)
RETURN()
At this point there is an obvious problem. Once the script runs and the if statement is run it follows on to run the runaway code, regardless of the outcome of the if statement. It also only runs once. This is taken care of with another label and another goto command. The label at the start of the script and a goto after the endif. This loops the script around forever.
The code should now look like this.
:loop
$proxclose = 50
  GOTO(runaway)
ENDIF
GOTO(loop)
:runaway
LEFT(255,1800)
FORWARD(255,5000)
RETURN()
The last thing to tackle is the demand the script above may have on the hardware and your PC. Reading from the ADC port can be demanding on the system. The way to overcome this is with a Sleep command, which pauses the script for the desired time.
Quote:
Sleep (milliseconds) Pauses for specified milliseconds Example sleeps for 1 second: Sleep(1000)
To restrict the number of reads of the ADC port we will add in the sleep right before it loops around, giving a sleep command for 1 second.
:loop
$proxclose = 50
  GOTO(runaway)
ENDIF
SLEEP(1000)
GOTO(loop)
:runaway
LEFT(255,1800)
FORWARD(255,5000)
RETURN()
And there we have it, the completed script. It's simple yet effective. The script will run, it will then check the value of ADC0, check if this is less than the minimum allowed value, if it is then it will jump down to the "runaway" sub routine, turn left, run forwards and return back to the main script. If not then it just loops around and around forever.
This post has not been written with the intention of showing a detection script but more for showing how to tackle writing any script. I hope you can now take what I have shared above and start creating your own scripts and routines to make the robot perform the tasks you require it to perform.
If you have any specific tasks that you would like to achieve but cannot quite figure out where to start please mention them and we can all discuss the way to do this, break it down piece by piece like the above and find you your solution.
#33
Ignore this, the forum update fixed the problem. I'll use this post for something else:)
#34
Wow! Thanks so much for taking the time to do this:) Im on a 2 week vacation and had planned out my days accordingly, each with a new set of tasks with the EZB4 Kit. Today and tomorrow were nothing but scripting basics, but was feeling a little lost. I've worked with Arduino and C++ a bit, and with tons of tutorials and videos available it was simple to get started with the basic principles do's and dont's. Now I've found my lesson plan in your Lesson/Thread! Blown away everyday by such an community and product! DJ, keep up the amazing work that you do! Love your passion:)
#35
If you can write C++ code for Arduino, you will find EZ-Robot scripting to be a piece of cake. It is much simpler.
That being said, it is possible you will find something you can't do. If that happens, there is a .NET SDK that can either totally replace ARC (lots of work) or communicate with ARC (in my opinion, the preferred direction).
About the only thing that an Arduino can do that would be very difficult with an EZ-B are very timing sensitive automation actions like a balance bot. However, if you you find you need something like that you could combine your existing Arduino skills with your new EZ-Robot skills by having the two devices communicate with each other via the UART port, so EZ give the commands and Arduino follows them and returns data. @Luis Vazquez gives a great example here: https://synthiam.com/Community/Questions/6577
Thanks:) Yes, im finding that as i move through the Tutorial, again, awesome job DJ!, great product. And the combination of the EZB4 and the Arduino is exactly the direction of the project. The Master controller is the EZB4 of course, but many functions will be handled by Arduinos coupled with a PCduino to allow multi platform programming to access/control various parts of the robot. Simple thing, rules can trip people up when learning a programming language, such as,
int yellowOnTime=250
Example: Once you know it, it seems obvious, but knowing that a Cap letter must used in the word On and Time in this string is a must, but without knowing that it is an actual rule, you could easily mistake it for a typo, an not realize how important it is. "basic principles do's and dont's".
So thats my mission today, is to understand the basic elements, and rules.
#37
Great comment about programming language rules. In EZ-Script, case sensitivity is not a rule. Where you see mixed case it is just for better readability. Proper use of parentheses, commas and quotation marks is where a lot of people get messed up.
I can see this to be very true. But the way DJ set this up with IntelliSense like programs like Atmel Studio, It will reduce the mistakes to a minimum. But oddly enough that seems to be half the fun when learning, is hunting down and finding that tiny little mistake:)
#40
It would not take much to change the script commands that use speech to instead use ControlCommand to the soundboard using variables to decide which MP3 to play. I wasn't offering it up as a complete solution, but rather a direction.
If you want me (or Rich) to write the script for you, I can add it to my already too long todo list, but you could figure it out a lot faster than waiting on me to get around to doing it for you;)
