Inverted Pendulum icon Inverted Pendulum — Balancing controller for Sainsmart v3 (and compatible) robots: PID tuning, real‑time telemetry, angle offset, movement and calibration via ARC. Try it →
Angle Sensor Compatible With Ez-B V4
Hi fellas,
I was planning on using an angle sensor to get readings in 2D plane, just the horizontal. I was wondering if anyone here has experience using such sensors in conjunction with EZ-b.
Following are the two low cost sensors i've considered so far, any advises and tutorials would be wonderful.
Option 1; https://dx.com/p/angular-transducer-tilt-slant-angle-sensor-module-for-arduino-150783
Option 2: https://dx.com/p/gy-272-3-axis-hmc5883l-compass-module-153211
PS i just need to measure the yaw movement, the rest comes from IMU. Thanks:D:)
Many people use the MMA7455 .. It's really easy to connect to the EZ-B's i2c port. There is a control for it under Add Control -> i2c -> MMA7455 Accelerometer
Thank you @DJ
