yesterday i got a bad charger.no problem i think,i got a spare one. but this one doesn do anything.voltage i get is 0.00
the adaptor gifs 12.29 volt
Camera Variable Overlay
— Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options.
@Nomad... Have you tried charging a battery with either one of the chargers? Check the voltage of your batteries as well before and after using the charger(s)... If it doesn't charge batteries you know you should use contact us... I think you should have posted this in your other "charger" thread since they seem to be identical problems. No need to create a new thread for the same issue....
ok thanks
