found this ir receiver.
Wrobot-Digital-38KHz-IR-Receiver
There is a transmiter for this too. Could this work with the ez-b?
TCP Client
— Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo
No. If you want to remote control your robot, consider using the wireless joystick that we promote from Logitech. Or use a wiimote.
Otherwise if you require ir, look under the I2c list. We support one device
We will have ir ez bits comin soon akso
Ok I'll stay tuned.
