Watson Speech To Text icon Watson Speech To Text — Watson Speech-to-Text ARC plugin: cloud AI transcription with configurable models, selectable VAD (Windows/WebRTC), audio capture and visualization. Try it →
Netherlands
Twitter YouTube
Lin/log: It depends on what you're planning to use it for. Linear potentiometers increase their resistance linearly, while Log does so exponentially. For audio purposes, I'd use the log potmeters and for any other purpose the linear ones.
I'm not sure what you mean by 'bits'
Sorry that's just the way I speak. By example, one of the descriptions is '16mm Rotary pot. 2K2 lin'. in there it says 2K2. another is '16mm Rotary pot. 4K7 lin' that one is 4K7. My question was what do these mean and is it important.
Cheers
Netherlands
Twitter YouTube
16mm is the lenght of the potmeter's shaft. Rotary means the shaft is twisted in order to move the wiper. 2K2 stands for the resistance of the resistive strip. When connecting the potentiometer to a microcontroller's analog in (like the EZ-B's), you should ideally use 10K (10 thousand ohms) to make sure your battery power does not go to waste. Anything higher than 1K would probably be fine. 2K2 = 2.2 kOhms (kilo ohms) or 2200 Ohms. 'lin' of course stands for linear like I explained to you in my previous reply.
Here's how you hook it up:
Hope I've answered all of your questions :D
it does thank you. You answered everything
Is one turn on the shaft enough? Most pots only turn one turn. You can also buy multi turn pots. Most common are 10 turn multi turn shafts. Here's a good one for under $5 USD:
www.robotshop.com/dfrobot-rotation-sensor-v2.html
There are other more expensive ones for about 5 times more but I'm using 2 of the above one and it works great and has a metal shaft.
Have fun, Dave Schulpius
