PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
Sorry, Never heard of it. With its documentation, you can build a plugin for it
#2   — Edited
Add more sensors to your Bioloid! The AX-S1 is housed inside the same casing as the AX-12 BUT the AX-S1 doesn't contain a motor - it is simply a sensing module that can be placed on the same serial network. The AX-S1 consists of:
an IrDA receiver for robot-to-robot communication, 3 IR reflection sensors (Left, Right & Front) that can be used to measure distance and luminosity, a microphone, and a piezo-electric sounder that can be used to play musical scales or simple a beeping sound. This actuator is meant to be used with the Bioloid system.
Yup seems kapoot!
