EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Resolved Resolved by Robot Doc!
Anyone Know The Value Of D1?
So, I took a gamble and replaced the already good Regulators. The EZB still doesn't work. All of the voltages are there. D1 has opened up and doesn't show any transistor or resistive, or capacitive readings, just completely OPEN. I need to know the value so I can replace it as a last shot at this. I have believed it was the cpu from the beginning. They used to sell those in the store for $15 , I think. Now, I have found this diode open.
So, does anyone know the value? I am guessing 5v Zenier?
I realize you may have been recommended one or more of these already but just to cover the basics......My concern at this point assuming everything else was correct that resistors are burned or the chip itself overvolted. Now is a good time to test the resistance of the resistors with a multimeter. Please remove the chip before doing this. Pay attention to the direction of the chip when removed. If the resistors show resistance within tolerance 10% more or less then clean the pins of the chip from any debris and reseat the chip. Apply power , connect to ARC and use the digital IO panel and set each port on and test. I did this with leds before very simple.
You can use basic leds (except red those are low voltage) to test them , doing it this way is safer that trying to hold multimeter probes on pins and accidentally slipping and shorting something out.
Thanks for the Good Advice. I need to find an SR240 Scholttky Diode. I have replaced the diode with a regular one. It may not work. If that doesn't work and I can not find the cpu, I am sunk. Do you think it is possible to find that cpu that has no firmware in it and do the EZB firmware program and bring it up that way? Or is this a special chip that is proprietary enough for it not to work?
P.S. It is also bad that we cannot give credit to more than one person. Many times many people are helpful.;)
In previous requests from other user DJ has said to use the "contact us" link to get replacement CPU, with the firmware. I think you need to get it from them because it needs their bootloader installed in order for the firmware updater to see it.
I have offered this to two other users who haven't taken me up on it. If you get to the point you just want to replace your EZ-B, I just ordered a V4 leaving me with a spare V3 board I don't need and would be willing to sell for what I paid for it plus shipping (which would be ~$5 for USPS delivery).
Contact me at [email protected] if you get to that point.
You can check s diode with continuity setting on your meter. Measured one direction it will beep then the opposite it should not. If you get a connection in both directions your diode is bad.
OK, You guys have been SO Helpful! I used Josh's diode trick and it looks like I gave credit where it was due to Robo-Doc. I took the cpu out and reseated it back and BANG! I have all my ports back now. The EZB doesn't look exactly the same because I have replaced all the parts. But, She's-a-working. I was going into a depression with EZB withdrawals. I could NOT imagine not having an EZB until DEC. Of course I had my second EZB to work with. But, I need them both in my Sunshine computer. So, when I get my arms and my shoulders in and my package from Tony. I have one from Anthony and one from Tony. I will be all set. I'm-a-walkin' on cloud 9. Thank you Jesus! I should've remember this same thing happened to me in 1976 on an 8080A cpu. I drove 4 Hrs to Houston and back. When I got there, the Dealer told me I should've checked that first. I remembered this for a long time, but forgot it recently. It was a new and so fresh, It did not dawn on me that it could have this problem.
Thanks to Everyone!
:D:D:D
I thought you tried re-seating the CPU before and it worked for a while and then stopped.
My offer stands if it flakes out on you again.
Thanks , Alan. You are a lifesaver.
#16
I'm glad that it works now.:)
