Semoic Range Sensor Module 10-180Cm Distance Sensor Tof10120 Distance Sensor
anyone heard of this?
Here is the info on this unit: https://dronebotworkshop.com/laser-vs-ultrasonic-distance-sensor-tests/
NMS Faux Odometry
— Estimate pose odometry from movement distance for robots without encoders, calibrated by speed. Suited for DIY navigation; pose drifts with lidar.
Nope, hadn't heard of it until you mentioned it. I'm guessing it has an STmicro Time-of-fight sensor inside.
https://www.st.com/en/imaging-and-photonics-solutions/vl53l0x.html
It seems a re-brand maybe a different pcb with the MTOF171000C0 sharp sensor: https://www.mouser.com/ProductDetail/Sharp-Microelectronics/MTOF171000C0?qs=byeeYqUIh0OTZ%2FjsWS07tw%3D%3D
https://github.com/sharpsensoruser/sharp-sensor-demos/wiki/Application-Guide-for-Sharp-MTOF171000C0-Time-of-Flight-Sensor-Module:
Great digging @ptp, you found the one!
I'm definitely interested in this sensor.
I had never seen the sensor before. But I did think it was rather good test the gentlemen did from DroneBotWorkshop (which I had also somehow never heard of or seen before).
What is your main interest in the sensor EZang60? Is it the small size? Did you have a specific application use in mind or just general robotic? At first I thought this sensor might make for a good short range sensor for robot claws/hands, but in my mind I think IR sensors probably still work well after seeing the whole test video.
Yes, I like the size
I guess I meant to ask is the small size for the sensor desired because you have a small robot or tiny flying drone or need a sensor in a robot claw where other sensors don't work as well?
The Dimensions of the Tof10120 are listed as: 10mm x 12mm x 3.5 mm The HC-SR04 Sonar sensor has the dimensions listed as: 45mm x 20mm x 15mm
The LaserPING from Parallax Inc which is pin compatible with the sonar unit and software compatible in ez-ARC using the 1pin setting and has the PCB dimensions of: 22mm x 16mm Just wanted to toss the LaserPING in the mix for a smaller alternative. As I'm about add a camera in my tiny Wall.e I'm going to see if I can squeeze a LaserPING in there too.
Good find on this sensor. I started a thread awhile back touching on these type of sensors:
https://synthiam.com/Community/Questions/Discussing-TOF-cameras-for-robot-vision-and-navigation-18561
Regarding the LaserPing https://www.parallax.com/product/28041: Is a different product is based on RFD77402: https://www.mouser.com/publicrelations_rfdigital_rfd77402_simblee_tof_2017final/ They are gone, Heptagon aquired RF Digital (RF Digital, Simblee) https://www.businesswire.com/news/home/20160608005868/en/Heptagon-Announces-Acquisition-RF-Digital-Corporation and then AMS (e.g. digital encoders sensors used by Dynamixel) gets both (https://ams.com/-/24-01-2017-ams-announces-completion-of-transaction-to-acquire-heptagon-and-related-capital-increase) and then shutdowns Heptagon, RF Digital, Simblee (RFDuino)
Parallax has stock... maybe they will deprecate the product like sparkfun's https://www.sparkfun.com/products/14539.
