It's amazing we made it to space at all! Wow, how far we've come...
— Edited
5 Participants
PCA9685 Servo Driver
— Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs.
I think it was programmed in machine language to boot.... These guys were the "real" rocket scientists... They needed more erasable memory or more processing power, though... On the Apollo 11 Lunar lander's decent to the moon the computer threw a 1201 and 1202 alarm. This indicated the computer was overloaded... The computer was supposed to land the LEM but as we know Neil Armstrong had to take control due to the fact the computer was trying to land in what looked like a boulder field...
Bet they wished they had an EZB....LOL
It is hard to believe we have more computer power in our phone then they had, to be able to fly from earth to the moon, land , and return safely. This technology has given so much to our every day life.
Ron R
In our home? A hand held calculator has more computing power than the Apollo guidance computer had... An arduino could have been used to do the entire mission... An EZB would have been a serious overkill....
Wow, wonderfully complex. The human mind is an amazing thing to come up with a system like the primitive computer. Amazing layer upon layer of complex processing needed, both in the building process of these "breadboard" type circuits and the way they worked. So many people building the different computer components, doing different simple processes in complex patterns assisted by other computers. I was amazed by the way the ladies were "sowing" the memory matrix thread by hand with needles and assisted by paper reel to reel tape to showing the proper hole to pass through. And how about the old paper, hole punched IBM cards telling the manufacturing computer and people the proper moves to make?
This kinda blows up the theory that we got our computer knowledge from a crashed Area 51 alien spaceship. No way an advanced spaceship traveling from across the galaxy came here with that technology. The way we built computer circuits back then was the first steps of evolution. If you really think of it, what we use now is very much the same as this primitive circuitry but much more compact and efficient. How about that wire woven memory core? WOW!
What is frightening is we sent human beings off into space depending on this very young and unproven technology. I think the fact they had such high quality material, skilled labor, stringent quality control and torture testing burn in period of components probably saved lives. Maybe it's a good thing these computers only had to run a few days properly before we left them on the moon, floating in outer space or bobbing in the ocean. However on the other hand they were very well and overbuilt with reliable material so who knows, this stuff could be still operable today. eek
Don't think an Arduino would have cut it - without heavy modification to the physical PCB's. Even an EZ-B would be cutting it close. The magnetic interference in space is considerable, because you're on the other side of the shield that protects us down here on earth. Most (if not all) consumer electronics would not function correctly in space, without significant re-design and appropriate shielding. And only certain ICs are designed for space use - I'm sure Atmel has some, but doubt Arduino is efficient enough for it.
When I worked contract for two projects used by NASA, one used Can-bus for use on satellites, shuttle and space station. Without getting into too many details, the project allowed communication between devices to discuss power consumption over can-bus. I was only working on the software side, but saw the hardware struggles that the engineers were dealing with. The requirements were vague until it got into the hands of their engineers for review - that's when a huge eye opener hit. I don't recall the exact details, but the PCB design and components were industrial quality - but not space quality. They kept having to revisit the entire product and re-design. It was actually embarrassing because our engineers thought they knew what they were doing
so did i!
Every decision that was made had to be documented while designing/implementing. There was more documentation than code! This is all because the conditions in space are/were quite intense. I write "were", because there may be improvements to shielding, etc in today's space tech. But back then there wasn't!
Look at the specs of the Apollo guidance computer and see how ahead of it's time it was - but still super limited:
[feature] Introduced August 1966; 49 years ago Discontinued July 1975; 40 years ago Processor Discrete IC RTL based Frequency 2.048 MHz Memory 16-bit wordlength, 2048 words RAM (magnetic core memory), 36,864 words ROM (core rope memory) [/feature]
Okay, that's 2 mhz in 1966 on something that only weighed 32kg! Remarkable!
To put this into perspective, the Apple ][ was released in 1977 and ran with 1mhz and shipped vanilla with 16kb of ram! You would have assumed that 11 years later, consumer electronics would be competitive.
So, would you have been comfortable going to space with an Apple ][ computer? ha - no way! I'll take the Apollo Computer, thank you! Even though it was still ridiculously crude for the job.
"More documentation than code". In my previous job I was doing some work for Lockheed Martin on an FAA job. We found a 1 line error in a piece of code we were working with a partner on. We had 20 pages of documents that needed to be filled out to allow us to fix the error.
Hardest project I have ever worked on.
Ha - man i can relate! Lockheed Martin are super dudilgent! I have mixed feelings about them
