EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
@Nomad Good thought, but it is a Surface pro tablet. No separate monitor, not auto-settings button.
Hopefully supporting more resolutions and visual settings is on DJ's ARC todo list. It seems this problem is only going to get worse as more vendors start delivering higher resolution displays and we should not have to limit our computer's capabilities to support one application, despite how important that one application is to us:)
ah thought it was a pc.
To get ARC to look close to proper on my high resolution screen for my laptop I had to follow the above advice (make all items smaller or larger, then slide to 100%). After that I then had to lower my resolution down to 1280 x 720. I was actually able to have it fill more of the screen by moving the before mentioned slider all the way to the right to 175% (NOT pictured below).
Before:
After:
Before looks way better
Microsoft really screwed up the screen dimension setting. It's a huge battle.
LOL DJ! Yes, it looks better from young 30's something eyes like yours. ;) Double your age (almost) to me and you're going to be making it as large as possible.
My mantra since I reached my mid 50's: More Light, Bigger Print! :D
Don't worry Dave, we will turn you into a robot soon enough!
