Tutorial icon Tutorial — Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images Try it →
Have you tried un-installing ARC... Re-boot your computer then do a fresh install of ARC?..... Sometimes Ockham's razor rules....
Can you share a sample file or code snippet?
It looks like there may be a bug with the array commands.
AppendArray doesn't look like it exists anymore. The examples for the array commands don't have valid syntax or have errors.
I guess DJ needs to take a look in to this. It may be a case of the examples not being updated or it may be something else, I don't know enough about arrays to know myself since I've yet to use them for anything more than just checking them out.
Hmmm.... I haven't used the array commands yet so I didn't notice the missing AppendArray command....
Fixed in the next release
https://natureofcode.com/book/chapter-9-the-evolution-of-code/
You can use arrays for genetic programming The above site does a great job on how to write the program in C++ and touches on interesting concepts. I used python to expriment with it.
It would be great if DJ could tweak Ez script to allow you guy's to try it out.
Thanks DJ , check out the link I think you'll find it interesting.
