Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Application Start Up Help
I know this is probably simple but i can't find it.
I have an project that uses ezbits. when i open the project it prompts for assembly instructions. How to get this to stop.
Also when loading a project from a short cut. the ARC does not prompt from calibration file.
I would be happy if i can just keep the assembly instructions from coming up . It is breaking the flow of interaction.
There is probably an easier way, but I just tried this and it worked.
I created a new project, then merged in my existing project. When asked if I wanted to merge the 3D model, I said no, but then on the next dialog, I selected all of the other objects. The new project no longer prompts me for assembly instructions (I had deleted the 3D model object previously -- I thought -- but that didn't resolve it).
No idea about your second question. When I get my Roli and start playing with calibration I may figure it out, but it may require an ARC fix.
Look at the ARC preferences settings
Thanks so much that fixed that up @DJ Sures. I just didn't see that. :)
anyway..
About loading from short cut.
I would like to have a ARC application short cut that can have the calibration settings stored in it so i loads automatically.
or another possible solution would be if you could load a calibration from script be give a file name.
I am really working hard to discover way of interacting with the bots and the ability to load a project and it run , unattended would be idea.
I am setting up a computer from the ground up to control EZ-Revolution robots.
So on boot up I would want to load up a ARC project and have it run with out prompt as this computer will be a server and in a closet.
There's another way the calibration will be working - i'm working on the new way, which you will like better.
The challenge with having you load it by a script is it cannot be saved with the file for sharing. If you make a project to share, the calibration would not apply to the other user. There are many logically challenges for EZ-Cloud distribution and fine tune profiles.
I have it taken care of and the new way will be done soon.
Well, if you want to do things the easy way, sure....;)
