Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Lebanon
Hello All! i am interfacing the ARDRONE with th ARC. i noticed that when tracking an object (for example a green ball), the debuger shows comments like (middle right, middle left...) i assume that it is related to the pixel position of the object on the grid. i wonder, is it possible to save the debuger results on a file?
You could create a script like this...
$filename = "c:\log.txt"
:START
IF ($CameraIsTracking = true)
  $line = "X: $CameraCenterX, Y: $CameraCenterY"
  fileWriteLine($filename, $line)
ENDIF
sleep(100)
GOTO(START)
Lebanon
thanks buddy... you are great. i am just new to all these stuff, it is for my PhD. i will remember of you in my dissertation. thanks a ton
Carlos.
Excellent!:)
Looking forward to seeing your creation!
