Ultrasonic Collision Detection icon Ultrasonic Collision Detection — Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling. Try it →
Yo D to the J,
I stumbled across this link that seems to be a starting point for some comprehensive info on extracting 2.0 video with some java classes....
https://projects.ardrone.org/boards/1/topics/show/5161
The meat of the info seems to be contained in a comprehensive discussion thread linked in that article. Good luck & hope you find this somehow useful.
-Kosdon3200
Any update on using the AR Drone 2.0 and ARC ? I tried the AR done panel and on pressing the connect button. It changes to Disconnect. But no video and no response from the AR drone to any command from ARC. Is there some trick to make the AR drone actually connect ? Kind of annoyed because I thought 2.0 would work. Watching your video I did not actually realize you were playing with an obsolete 1.0
  • heliboy
Update ... on last post. I was able to connect to the AR Drone and get it to take off etc. But no video feed. So, some progress.
  • heliboy
