EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
Arduino Infrared Module Kit As Table Top Edge Sensor?
in the video below i think the guy is using the arduino infrared module kit (link to ebay item below too)
i wanted to see if anyone here know if we can use this kit as edge detection. so my wall-e doesn't fall of the table.
in the video it shows that if even one sensor (either the transmitter or receiver ) go off the table the bot stops and reverses....
Can i assume the 2 sensors are always communicating the same voltage/value? and once that value changes (table is no longer there) the scrip command is to back up?
thanks in advance
ebay link to transmitter and receiver sensors
also, can this one be uses as a microphone? for voice commands? found it on the same site you posted...3 wires too...
what do you think? link
Netherlands
Twitter YouTube
No, you can't hook up a microphone directly to the EZ-B, you need a wireless microphone that is connected to your PC blush
i was hoping that wasnt the case, well you saved me 50 bucks in sensors....thats man... going tithe mp3 trigger and the sensor you posted...
Netherlands
Twitter YouTube
Glad to have helped:D
@hoolagen1, Generally you don't want a mic in the robot because the robot is too loud. DJ recomends using the computer mic or table top mic. I use the one on my web cam. Works great!
