Text Overlay icon Text Overlay — Overlay a variable on a processed camera image at X/Y coordinates; name the variable and attach to a specific or any available camera Try it →
Resolved Resolved by Athena!
Arduino Loop Increment Issue Fix
@Athena,
I am currently running the following code on an Arduino Mega to adjust a variable iteratively:
float psudoActCrs = 90.7550;
float actualCourse = 92;
while (true) {
  if (psudoActCrs < actualCourse) {
    psudoActCrs += 0.1;
  if (psudoActCrs > actualCourse) {
    psudoActCrs -= 0.1;
  Serial.print("psudoActCrs:  ");
  Serial.println(psudoActCrs, 4);
  Serial.print("actualCourse:  ");
  Serial.println(actualCourse, 4);
  if (psudoActCrs == actualCourse) {
    break;
My aim is to increment 'psudoActCrs' by 0.1 in each iteration of the loop until it matches or exceeds 'actualCourse'. However, I want to avoid triggering both conditions (< and >) at the same time. How can I properly manage the loop so it exits correctly when 'psudoActCrs' equals or exceeds 'actualCourse'?
Thanks,
Jack
USB
Digital 21
Serial Terminal by Synthiam
PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex
Arduinocoms by ShadowStudios
EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control
Good question - this is a classic floating-point loop issue. Two points to keep in mind:
  • Never rely on exact equality with floats (e.g., psudoActCrs == actualCourse) - binary floating point rarely hits decimal steps exactly.
  • Prefer a loop condition that directly represents your stopping criteria (e.g., loop while psudoActCrs < actualCourse), or use an integer/tenth representation to avoid rounding problems.
Below are two robust solutions for Arduino (Mega/Due) you can use.
  1. Keep floats, use an epsilon and explicit loop condition
  • Loop while psudoActCrs is less than actualCourse.
  • Use a small tolerance (epsilon) to detect "close enough".
  • Optionally clamp to actualCourse when you exceed it.
float actualCourse = 92.0;
const float step = 0.1f;
const float EPS = 0.0005f; // tolerance
while (psudoActCrs + EPS < actualCourse) {   // loop until we reach (within EPS) actualCourse
  psudoActCrs += step;
  // if we overshot, clamp to exact value
  if (psudoActCrs > actualCourse) psudoActCrs = actualCourse;
  delay(10); // optional, prevents hammering serial/CPU
  1. Best: use integer math (avoid float rounding)
  • Multiply values by 10 (or 100) and use integers.
  • This avoids floating-point rounding entirely when stepping by 0.1.
float psudoActCrs_f = 90.7550;
float actualCourse_f = 92.0;
int psudoTenths = (int)round(psudoActCrs_f * 10.0f);  // e.g. 907
int actualTenths = (int)round(actualCourse_f * 10.0f); // e.g. 920
while (psudoTenths < actualTenths) {
  psudoTenths += 1; // one tenth
  float psudoActCrs = psudoTenths / 10.0f; // for printing or use
  Serial.println(actualCourse_f, 4);
  delay(10);
// convert back if needed
psudoActCrs_f = psudoTenths / 10.0f;
Notes and tips
  • Use while(psudoActCrs < actualCourse) rather than while(true) so the loop termination is explicit.
  • If your start value can be greater than actualCourse, handle both directions (increment or decrement) or normalize using the integer method with comparison operators (< or >).
  • Add a safety counter or timeout if the values could be modified elsewhere to avoid infinite loops.
  • If you need the variable to exactly equal actualCourse at the end, clamp it (psudoActCrs = actualCourse) after exiting the loop.
If you want, I can:
  • Show the version that supports both incrementing and decrementing depending on start vs target.
  • Convert this into a small ARC-compatible JavaScript/Python script if you plan to run the iteration inside an ARC script instead of the Arduino firmware.
Also: since you mentioned Arduino Due/Mega EZB firmware, here’s the Synthiam support page in case you want to review firmware details: https://synthiam.com/Support/Hardware/Arduino-Due-Mega
Which behavior do you want if psudoActCrs starts above actualCourse - decrement or still increment?
Thank you @Athena.  I am using your 2nd recommendation.
Best: use integer math (avoid float rounding) Multiply values by 10 (or 100) and use integers.
Jack
Nice choice - integer math will make this robust and simple. Below are compact, safe examples you can drop into your Arduino Mega sketch. They use a multiplier (10 for 0.1 steps, 100 for 0.01, etc.), handle both incrementing and decrementing, include a safety counter, and clamp the final value to the exact target if you want an exact match.
Important notes:
  • Use lround() (or round()) when converting floats to integers to avoid truncation bias.
  • Use long (or int32_t) for the integer representation to avoid overflow if you scale by 100+.
  • Add a safety timeout to avoid infinite loops if something else changes the values or they never converge.
  1. Basic tenths (0.1 steps) - handles both directions
// Multiply by 10 to step by 0.1
long psudoTenths = lround(psudoActCrs * 10.0);
long actualTenths = lround(actualCourse * 10.0);
// Determine step direction
int step = (psudoTenths < actualTenths) ? 1 : -1;
// Safety counter
unsigned long safety = 0;
const unsigned long SAFETY_LIMIT = 100000UL;
while ((step > 0 && psudoTenths < actualTenths) ||
       (step < 0 && psudoTenths > actualTenths))
  psudoTenths += step; // one "tenths" per loop -> +/-0.1
  float psudoActCrs_now = psudoTenths / 10.0f;
  Serial.println(psudoActCrs_now, 4);
  delay(10); // throttle loop / friendly to CPU & Serial
  if (++safety > SAFETY_LIMIT) {
    Serial.println("Safety limit reached, breaking loop");
    break;
// Optional: clamp to exact target if you require exact equality
Serial.print("Final psudoActCrs (clamped): ");
  1. If you need higher resolution (0.01 steps) - multiply by 100
// same pattern but use multiplier = 100
long psudoHundredths = lround(psudoActCrs * 100.0);
long actualHundredths = lround(actualCourse * 100.0);
int step = (psudoHundredths < actualHundredths) ? 1 : -1;
// loop same as above, divide by 100.0 when printing
Why this fixes your original problem
  • Floating point addition/subtraction by 0.1 rarely lands exactly on decimal values due to binary representation. Integer math (stepping tenths/hundredths) avoids that.
  • The loop condition uses < or > on integers, so you won't miss the target or get stuck expecting exact float equality.
  • Clamping at the end guarantees the final variable equals actualCourse if you need that.
Want this as an ARC-compatible JavaScript/Python snippet instead?
  • I can convert the same logic to an ARC script (JavaScript preferred per Synthiam guidance) if you intend to run the loop inside ARC rather than on the Arduino firmware.
Also: are psudoActCrs and actualCourse only local variables on the Arduino, or do they get updated from sensors/ARC while the loop runs? If values can change externally, that affects whether you should use a loop like above or a step-per-timer approach.
