On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
Arduino Mega Is Being Powered Through The Uart Serial Tx/rx Connection
Arduino Mega Is Being Powered Through The Uart Serial Tx/Rx Connection
So I want to control the Arduino power using this RFP30N06LE MOSFET and that works as expected when hooked up to EZ-B D0. However, if the serial TX/RX is connected to the Arduino it get's power via the serial lines bypassing the D0 MOSFET. Any comments / ideas on controlling power and having Serial TX/RX lines connected?
Naw, reversing the tx and rx lines wouldn't do it, both the EZ-B and Mega have 5V tolerant I/O.
Are you sure your battery isn't low?
I feel the arm micro on the eZb is damaged by sinking the mega over the I/o lines. The trouble is with what I had responded to earlier. The latch on the mega's I/o is holding the pin to gnd, which is sinking from the I/o of the ezb.
That is the trouble with this approach. I have some interesting experience in the video game industry with a historical application that my father had designed which allowed multiple games to exist in a single cabinet. A switch would allow the user to cycle between the pcbs. He had to use relays on both the power and I/o due to a similar issue. The GND would connect across the separate pcb I/o ports and power the games all at once - causing all sorts of issues. The solution as to use Relays on every I/o, which of course isn't what you need to do. The solution for your application is to use a mosfet which controls the Power, not GND.
Internally, on microcontroller I/O (or any I/O IC) are something called "latches". Specifically on a multi-use I/o, the latch configures the operating mode. However, on digital I/o it really simply switches between floating, gnd or vcc. When the power is off, the I/o latches to GND - I believe gnd generally is the native logic state.
So, in short... the ez-b was providing a GND short for the atmel through it's I/O which was latched to GND and voila.... power. Sadly, the ez-b's ARM was damaged because it is unable to sink enough current for the atmel and its peripherals.
After sleeping on it I think I understand what happened now. The wiring was correct it was the component selection that wasn't.
DJ is correct in saying that the ez-b likely was sinking the current needed by the Mega through a ez-b serial I/O line. This is because the N-channel MOSFET you chose toggles the ground connection ON and OFF, but the Vin line passes right through and was always connected, since by default the N-channel MOSFET was not active and the ground line was open and the circuit looked for the path of least resistance to ground and that was through the ez-b. Unfortunately the Mega draws more than an I/O pin can handle.
I also verified this morning that a powered up ez-b does not power up a Mega through the serial lines, just in case someone had that question in the future.
What was really needed was a P-Channel MOSFET that toggles the Vin line ON and OFF.
As an example: In common H-bridge design, P-Channel FETs switch the positive voltage side of the circuit and N-Channel FETs switch the negative side, this is how they are designed to be used.
Okay, here's my lesson. I took the details for granted on sparkfun's site concerning the MOSFET Power Control Kit from reading the product summary it seemed like a good fit. What I failed to realize, do to my very limited understanding of electronics, was the very details that were not obvious on their site concerning the mosfet. I did not do the research I should have done even though I probably wouldn't have understood it. Since I did not understand mosfets or ic grounding I just day dreamed I was gonna be able to put the robot in a low power state using the mosfet as in turning off arduino and peripherals. The storm clouds were gathering and I decided to hook up two of these
NeoPixel Ring - 16
and crack! EZB goes down permanently! I assume because of the current draw and the grounding into the serial lines as I had removed the grounding wire on D0 thinking I was removing the grounding controlled by the mosfet. Serious bummed ezb no connects to ARC.
So, several lessons were learned here. Grounding what is and where's it going. Component research is a good idea. Finally, before I go cowboy maybe I should run my plan by the helpful experts here on this forum.
Blue smokes 3, Leversofpower 1. The struggle continues... eek
lol! Love that story - well written. We will help you get up and running:)
For other robot builders:
p channel mosfet is used on the positive side of the load whereas an n channel mosfet is used on the negative or ground side of the load. When triggered, a p channel mosfet connects the input on the load to the positive source whereas an n channel mosfet connects the output from the load to ground or the negative source.
So I am assuming n-channel probably doesn't have a lot of uses with ezb and power controlling shenanigans.
On a side note I did find it interesting that the EZB can be damaged and you can still connect to it wifi directly and connect to 192.768.1.1
#15
So curiosity got the better of me and I had to try out turning input voltage on and off with a P-Channel FET. Turns out that a few more components are needed to make it work. Here's the circuit diagram:
Here's the reason for the extra components:
  • In order for a P-Channel MOSFET to be deactived by default a pullup resistor (R2) must be added to the gate of the FET, since P-channel FETs are activated with a low signal
  • If R2 is present then you cannot control the MOSFET's gate with an I/O line because the I/O would be pulled up to the input voltage and would be damaged, so we need to add a simple switching transistor to bring the gate voltage low
  • If a transistor is being used then a inline resistor is needed to activate the base since transistors are by nature a current activated device
  • The MOSFET I was using is an older style FET and needs a large voltage at the gate, there are new MOSFETs on the market that are meant to be switched with TTL (3.3/5V) logic so using one of those I may have been able to do away with the transistor
If you'd like to see the circuit in action I've uploaded a video of the operation to dropbox.
#16
@leversofpower at least you look at it as a lesson not as a disaster. I'm sure you're aware of how helpful the community is so double checking circuits is always a good idea, especially if you don't have much/any knowledge in electronics.
@Jeremie, thanks for the schematic, that's going to come in handy! Consider it saved with all of the other useful schematics and info I seem to have acquired over the last 2 years.
