Script Collection icon Script Collection — Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands. Try it →
I already have the Motor Sheild. I bought a bunch of Arduino stuff for some F/X Animatronic projects, then I stumbled into EZ Robot. Does this mean I need to buy another motor controller?
Did any documentation come with the shield ? It should be able to interface with the EZ-B, it will require knowledge of what battery power connections are available to drive dual electric motors at a certain voltage and operational amperage as well as what connections are on the shield for PWM input control.
The datasheets which should have either come with the arduino stuff or should be available from where you bought it should have the required schematics with the VCC, Ground, PWM, VM etc. etc. etc on.
If you can link to the datasheets or provide us with details of the shields someone should be able to tell you how to wire it up.
Ecuador
I think that yes! You can use it, but I not Recommend you to do that , better if you can get an H-Bridge.
@doombot if everything is labeled the answer is yes you can , follow the labeling. The ezb version 3 , the most recent version that was available to purchase was made to accept standard arduino shields. There is a shield compatibility chart I posted a while back too if you search for it or look under my profile of threads posted.
Really? Why don't you recommend? I wanna know:) I've seen applications where people use the digital out directly to run motors, just using a transistor and a diode. Can a motor controller be bypassed then using this method?
