Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Resolved Resolved by Athena!
Arduino PWM Bearing Control Help
Hi @Athena,
I'm requesting help to add capabilities to an existing Arduino sketch. The sketch is included at the end of this post. Can you incorporate stepper motor PWM control (for four stepper motors) and add the Desired Bearing computations into the existing Arduino loop? Thank you in advance.
For clarity, here is the system context:
  • ARC (Synthiam Autonomous Robot Control) runs on an EZB4 and provides the high-level navigation, vision, and script coordination.
  • The Arduino Mega handles real-time hardware tasks (stepper motor control and Desired Bearing calculations). Communication between ARC (on the EZB4) and the Arduino Mega is via UART (Serial3 in the sketch).
  • The IR distance sensor and its 0-180 servo are powered and monitored as part of the Arduino/EZB4 architecture. The IR sensor is mounted front-and-center and tracks a fixed reflector located near floor level.
  • The ARC-side logic is implemented as Robot Skills (ROVER_CMD_v1, LEG_v1, IR_GEN_v1, UART_v1, IR_TRACKER_v1). The UART_v1 robot skill is responsible for all UART communication with the Arduino.
  • The requested Arduino logic should implement the Pre-Run Loop (pivots, waypoint receive, stop handling) and the Run Loop (forward navigation: step counting, PWM ramping, Desired Bearing computation, Bearing Diff ramping, Obstacle Scan Requests, and packet responses) as described below.
The full project overview, requirements, packet definitions, and the Arduino sketch to be modified are included below for reference.
ARC Rover: Arduino PWM Control and Bearing Computation
PART 1.   General Overview
PART 2.   Term Definitions
PART 3.   Requested Criteria for the Arduino Sketch
PART 4.   Arduino Sketch to be modified with PART 3 Criteria
PART 1
General Overview for informational purposes:
This rover is driven by 4 stepper motors rolling on 4" mecanum wheels and powered by a 24v 5000mAh lithium battery. Individual buck converters supply the appropriate DC voltage to the EZB4, Arduino Mega, IR distance measuring sensor, and the IR sensor servo. The IR sensor is mounted to a 0-180 degree servo centered at 90 degrees. This gives the IR sensor equal travel left (180) and right (0) of center (90).  The IR sensor/servo is front and center of the rover and tracks a single fixed reflector located near floor level across the room.
The principal purpose of this rover is to explore and develop a navigation system based upon the Sharp IR distance measuring sensor. Overall controlling architecture is accomplished via Synthiam ARC on the EZB4.  Certain high CPU demands such as stepper motor control and Desired Bearing computations are accomplished by an Arduino Mega.  Necessary communication between ARC and the Arduino is via UART.
This rover project is very much a work in progress. Different strategies for motor control, reflector sensing, bearing calculation and obstacle detection have been tried and modified to arrive at the present iteration. What follows represents the latest embodiment of this rover project.
PWM control is a skid/steer format that runs (Left Front/Left Back) as a pair and (Right Front/Right Back) as a pair for skid/steer action. Other mecanum wheel capabilities will be developed as necessary.
ARC Rover Control Architecture:
Individual ARC Scripts for Overall Rover Control
1. ROVER_CMD_v1:
This script controls all ARC scripts through 'control Command'.
2. LEG_v1:
This script defines the Waypoint Data for the rover path. It sets global variables necessary for each leg and operates only once.
3. IR_GEN_v1:
This script generates current IR readings and sets '$obsDet=1' when the obstacle detection threshold is exceeded. It operates in a continuous loop.
4. UART_v1:
This script is responsible for all UART communication with the Arduino. It operates in a continuous loop, acting upon global variable status.
5. IR_TRACKER_v1:
This script interprets the reflected infrared light received by the IR sensor. Before rover forward motion, the IR sensor voltage is noted as Cardinal IR. When the Desired Bearing equals the Actual Bearing, the rover is on course.  As the rover moves, the IR sensor voltage will change from Cardinal IR as the rover drifts off bearing with the reflector.  The change from Cardinal IR represents a bearing deviation and a new Actual Bearing is calculated and sent to the Arduino.
PART 2
Term Definitions:
Actual Bearing:  The actual angle between the IR sensor and the reflector. ARC calculation.
Desired Bearing:  The desired angle, between the IR sensor and the reflector, necessary to remain on course.
                  Arduino calculation.
Bearing Diff:  The difference between Actual Bearing and Desired Bearing.  Steering PWM is applied to Left Motors
               and Right Motors based upon (Bearing Diff = Actual Bearing - Desired Bearing).
               Actual Bearing is sent to the Arduino by ARC as an X100 representation.
      EXAMPLE (Actual Bearing of 79.00 is sent by ARC as 7900). Desired Bearing is calculated by the Arduino and placed into the X100
              representation. Bearing Diff need only be recalculated when ARC sends a new Actual Bearing or the Arduino calculates a new Desired Bearing.
Leg always refers to the physical track of the rover.  Measured in inches and converted to Combined Steps. One inch = 437.5 Combined Steps.
Leg Start Point:  The beginning point of navigation.
Leg Stop Point:  The end point of navigation.
Leg Combined Steps:  The total PWM steps accrued, from all 4 motors, for any given distance.  One inch = 437.5 Combined Steps.
Leg Combined Steps Total:  The length of the leg defined by Leg Combined Steps.  The distance between the Leg Start Point and the Leg Stop Point.
Leg Combined Steps Taken:  The distance traveled in Leg Combined Steps.
Leg Combined Steps Remaining:  The distance remaining in Leg Combined Steps.  (Leg Combined Steps Total - Leg Combined Steps Taken).
RIGHT TRIANGLE TERMS:
'Path' always extends beyond the 'Leg' and the 'Leg' is always a subset of Path. One inch = 437.5 Combined Steps.
'Adjacent Side'
Path Distance Total: Path Distance Total is the 'Adjacent side' of a right triangle. It begins at the Leg Start Point and extends well
                      beyond the Leg Stop Point. Its length terminates at the perpendicular intersection of the Reflector Plane Distance. Measured
Path Distance Taken:  The distance traveled, measured in Leg Combined Steps.
Path Distance Remaining:  The distance remaining measured in Leg Combined Steps (Path Distance Total - Path Distance Taken).
'Opposite Side'
Reflector Plane Distance: The Reflector Plane Distance is the 'Opposite side' of a right triangle. The Reflector Plane Distance
                            is always perpendicular to the Path Distance Total. Its length is a fixed distance, measured in Leg Combined Steps,
                            between the Path Distance Total and the physical reflector.
PART 3
Requested Criteria to be added to the Arduino Sketch:
    1. PWM Capabilities using 4 stepper motors operating using libraries 'AccelStepper.h' and 'MultiStepper.h'
           AccelStepper LeftFrontWheel(1, 3, 6); // pins
           AccelStepper LeftBackWheel(1, 2, 5);  // pins
           AccelStepper RightFrontWheel(1, 12, 13);  // pins
           AccelStepper RightBackWheel(1, 4, 7);  // pins
    Pre-Run Loop:  Pre-Run Loop is the default loop and is active only when Run Loop is deactivated.
    Monitors for the following packets/commands sent by ARC:
    Each pass through the Pre-Run Loop:
    1. Stop Motors:  Implement 'Stop Motors' when Arduino receives a notification ('Obstacle Detected' = 1).
                     Respond to Stop Motor command by sending 'Total Steps Taken' to ARC.
    2. Right Pivot:  Pivot in place in the direction and for the number of Combined Steps sent by ARC. Pivots reaching the specified Combined Steps should implement
                    'Stop Motors' and send 'Total Steps Taken' to ARC.
    3. Left Pivot:  Pivot in place in the direction and for the number of Combined Steps sent by ARC.  Pivots reaching the specified Combined Steps should implement
    4. Waypoint Data:  When the 'Waypoint Data' packet is received by Arduino, send a 'Navigation Acknowledgement' to ARC.
    Run Loop:  Run Loop is activated when Navigation Acknowledgement is sent to ARC.  Pre-Run Loop is deactivated.
    Monitors for the following packets/conditions sent by ARC:
    Each pass through the Run Loop:
    1. Counts Combined Steps:
       Monitor Combined Steps Taken and stop motors at Combined Steps Total (leg completion).
    2. Motor starting PWM is applied with a 'ramp' up to normal speed.  Incremental ramp steps accrue during each pass through the Run Loop.
       When normal speed is reached, this ramp up to normal speed is terminated.
    3. Monitors when Actual Bearing changes are sent by ARC.  Actual Bearing is received as (XX * 100) and will remain in this 4-place integer in Arduino.
    4. Calculates Desired Bearing at selected intervals.
       Desired Bearing is converted from XX.XX to (XX.XX * 100) and remains in this 4-place integer.
       Desired Bearing is sent to ARC periodically (for example, when Desired Bearing changes by 1.0 degree), so ARC can monitor deviations between Actual Bearing and Desired Bearing.
       (See SUBSECTION: DESIRED BEARING CALCULATIONS below for more on Desired Bearing)
 NOTE:  Whenever Actual Bearing OR Desired Bearing changes, a Bearing Diff must be calculated.
    5. Bearing Diff:
     a.  Bearing Diff is reset to '0'.  Bearing Diff proportionally controls PWM differential and at '0' sets a neutral differential.
     b.  A new Bearing Diff is calculated. (Actual Bearing - Desired Bearing = Bearing Diff)
     c.  Bearing Diff is 'ramped' from '0' to the new Bearing Diff.  Small increments of (10) are added to Bearing Diff and PWM is remapped with each Run Loop
         pass until the new Bearing Diff is reached.
         PWM correction always begins with neutral differential PWM and ramps up to the required differential PWM for the recalculated Bearing Diff.
 Example:  Actual Bearing = 8800 (88.00).  Desired Bearing = 9000 (90.00).  Bearing Diff = -200.    (8800 - 9000) = -200
           Bearing Diff is set to '0'.  Each pass through Run Loop accumulates an additional (-10).  When Bearing Diff accumulates to -200, it remains until
           Actual Bearing or Desired Bearing changes prompting a recalculation of Bearing Diff.
           Actual Bearing = 9200 (92.00).  Desired Bearing = 9000 (90.00).  Bearing Diff = 200.     (9200 - 9000) = 200
           Bearing Diff is set to '0'.  Each pass through Run Loop accumulates an additional (+10).  When Bearing Diff accumulates to +200, it remains until
     6. Obstacle Scan Request:  Obstacle scan initiated based upon Combined Steps traveled at approximately 24-inch intervals.
     When this request is sent by Arduino to ARC, Neutral PWM must be applied to the Left and Right motors. Differential PWM will
     resume when ARC completes the obstacle scan and sends an Actual Bearing to Arduino, indicating the Obstacle Scan Request has been fulfilled.
     7. Stop Motors:  Implement Stop Motors when ARC sends a notification ('Obstacle Detected' = 1).
                      Send Total Steps Taken in response to the Stop Motor command.
    Desired Bearing is calculated entirely by the Arduino in ONE of two ways (A or B):
    A) If Waypoint Data received indicates Bearing Alignment 0 (DA), then the Desired Bearing is fixed and never changes, remaining at 90.  [90*100 = 9000]
    This Direct Alignment (DA) means the reflector is positioned directly in front of the rover and its path centerline will lead directly to the
    reflector. Desired Bearing is never recalculated.
    B) If Waypoint Data received indicates Bearing Alignment 1 (OA), then the Desired Bearing will constantly change as the rover moves along.  The
    Desired Bearing may, for instance, start at 83.00 [8300] and end at 71.00 [7100].  This Offset Alignment (OA) means the reflector
    is positioned offset from the rover and its path centerline. Desired Bearing is calculated at Combined Step intervals of 100.
    The trigonometry calculation of a right triangle is used for an Offset Alignment (OA) reflector:
                       Tangent = Opposite (Reflector Plane Distance) / Adjacent (Path Distance Remaining)
    If Waypoint Data received indicates Track Direction = 0 (FD), then the following is applied for forward direction:
    Path Distance Remaining = (pathDistanceTotal - abs(legCombinedStepsTaken));
    If Waypoint Data received indicates Track Direction = 1 (RD), then the following is applied for reverse direction:
    Path Distance Remaining = pathDistanceTotal - (legCombinedStepsTotal - abs(legCombinedStepsTaken));
    if (desiredBearing < 90) {
      desiredBearing = (atan2(reflectorPlaneDistance, PathDistanceRemaining) * 180/PI) - 90;
      // a positive angle is required, use the absolute value
      desiredBearing = abs(desiredBearing);
    // Use atan2 to calculate the angle correctly
    if (desiredBearing > 90) {
      desiredBearing = (atan2(reflectorPlaneDistance, PathDistanceRemaining) * 180/PI) + 90;
PACKETS:
ARC -> Arduino Packets:
1. Stop Motors (rover full stop)
Byte	Value
Header	0xA5
Command	0x01
Payload	none
Packet size: 2 bytes
2. Actual Bearing (Bearing to the reflector)
Actual bearing is sent as a whole number scaled by 100.
Example:
79.00 degrees becomes 7900
sent as a 16-bit unsigned integer
Byte	Value
Header	0xA5
Command	0x03
Byte 2	Low byte of bearing
Byte 3	High byte of bearing
Packet size: 4 bytes
3. Right Pivot
Byte	Value
Header	0xA5
Command	0x04
Byte 2	Low byte of step count
Byte 3	High byte of step count
4. Left Pivot
Byte	Value
Header	0xA5
Command	0x05
5. Waypoint Data
Byte	Field	Type	Notes
0	Header	0xA5	packet marker
1	Command	0x06	waypoint packet
2-5	Path Total Distance	uint32	max 120000
6-9	Combined Steps Desired	uint32	max 84000
10-13	Opposite Distance	uint32	max 24000
14	Bearing Alignment	uint8	0 = DA, 1 = OA
15-16	Reflector Bearing	uint16	scaled by 100
17	Sensor Prime	uint8	1-10
18-19	Desired Bearing	uint16	scaled by 100
20-21	Actual Bearing	uint16	scaled by 100
22	Track Direction	uint8	0 = FD, 1 = RD
Packet size: 23 bytes
Arduino -> ARC Packets
1. Navigation Acknowledgement (confirmation of Waypoint Data received)
Byte	Value
Header	0xA5
Command	0x10
Payload	none
2. Total Steps Taken (response to Stop Motor command)
Use a 32-bit unsigned integer.
Byte	Value
Header	0xA5
Command	0x11
Byte 2	Total steps byte 0
Byte 3	Total steps byte 1
Byte 4	Total steps byte 2
Byte 5	Total steps byte 3
Packet size: 6 bytes
3. Desired Bearing (course computed for desired rover path)
Byte	Value
Header	0xA5
Command	0x12
Byte 2	Low byte
Byte 3	High byte
4. Obstacle Scan Request (obstacle scan initiated based upon distance traveled)
Byte	Value
Header	0xA5
Command	0x13
Payload	none
PART 4.
Arduino Sketch to be modified:
#include <Arduino.h>
static const uint8_t UART_HEADER = 0xA5;
// ARC -> Arduinostatic const uint8_t CMD_STOP_MOTORS      = 0x01;static const uint8_t CMD_MISSED_IR        = 0x02;static const uint8_t CMD_ACTUAL_BEARING   = 0x03;static const uint8_t CMD_RIGHT_PIVOT      = 0x04;static const uint8_t CMD_LEFT_PIVOT       = 0x05;static const uint8_t CMD_WAYPOINT_DATA    = 0x06;static const uint8_t CMD_OBS_SCAN_COMPLETE = 0x07;
// Arduino -> ARCstatic const uint8_t RSP_NAV_ACK          = 0x10;static const uint8_t RSP_TOTAL_STEPS      = 0x11;static const uint8_t RSP_DESIRED_BEARING  = 0x12;static const uint8_t RSP_OBS_SCAN_REQUEST = 0x13;
enum ParserState {  WAIT_HEADER,  WAIT_CMD,  WAIT_PAYLOAD};
ParserState state = WAIT_HEADER;uint8_t currentCmd = 0;uint8_t payload[32];uint8_t payloadIndex = 0;uint8_t expectedLength = 0;
int RUN = 0; // 0 = setup / pivots / waypoint receive, 1 = forward navigation
uint32_t totalStepsTaken = 0;uint16_t desiredBearing100 = 0;uint16_t lastDesiredBearing100 = 1;uint16_t actualBearing100 = 0;
uint32_t pathTotalDistance = 0;uint32_t combinedStepsDesired = 0;uint32_t oppositeDistance = 0;uint8_t bearingAlignment = 0;uint16_t reflectorBearing100 = 0;uint8_t sensorPrime = 0;uint16_t waypointDesiredBearing100 = 0;uint16_t waypointActualBearing100 = 0;uint8_t trackDir = 0;
uint16_t readUInt16LE(const uint8_t* data) {  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);}
uint32_t readUInt32LE(const uint8_t* data) {  return (uint32_t)data[0]      | ((uint32_t)data[1] << 8)      | ((uint32_t)data[2] << 16)      | ((uint32_t)data[3] << 24);}
void writeUInt16LE(uint16_t value) {  Serial3.write((uint8_t)(value & 0xFF));  Serial3.write((uint8_t)((value >> 8) & 0xFF));}
void writeUInt32LE(uint32_t value) {  Serial3.write((uint8_t)(value & 0xFF));  Serial3.write((uint8_t)((value >> 8) & 0xFF));  Serial3.write((uint8_t)((value >> 16) & 0xFF));  Serial3.write((uint8_t)((value >> 24) & 0xFF));}
void sendHeaderAndCmd(uint8_t cmd) {  Serial3.write(UART_HEADER);  Serial3.write(cmd);}
void sendNavAck() {  sendHeaderAndCmd(RSP_NAV_ACK);  Serial.println("TX: NAV ACK");}
void sendTotalSteps(uint32_t steps) {  sendHeaderAndCmd(RSP_TOTAL_STEPS);  writeUInt32LE(steps);  Serial.print("TX: TOTAL STEPS = ");  Serial.println(steps);}
void sendDesiredBearing(uint16_t bearing100) {  sendHeaderAndCmd(RSP_DESIRED_BEARING);  writeUInt16LE(bearing100);  Serial.print("TX: DESIRED BEARING x100 = ");  Serial.println(bearing100);}
void sendObstacleScanRequest() {  sendHeaderAndCmd(RSP_OBS_SCAN_REQUEST);  Serial.println("TX: OBSTACLE SCAN REQUEST");}
void stopMotors() {  Serial.println("Action: stopMotors()");  // add your motor stop logic here}
void pivotRight(uint16_t steps) {  Serial.print("Action: pivotRight(");  Serial.print(steps);  Serial.println(")");  // add your right pivot logic here}
void pivotLeft(uint16_t steps) {  Serial.print("Action: pivotLeft(");  Serial.print(steps);  Serial.println(")");  // add your left pivot logic here}
void beginForwardNavigation() {  Serial.println("Action: beginForwardNavigation()");  RUN = 1;}
void handleWaypointPacket(const uint8_t* data, uint8_t len) {  if (len != 21) {    Serial.print("Waypoint length mismatch: ");    Serial.println(len);    return;  }
  pathTotalDistance = readUInt32LE(&data[0]);  combinedStepsDesired = readUInt32LE(&data[4]);  oppositeDistance = readUInt32LE(&data[8]);  bearingAlignment = data[12];  reflectorBearing100 = readUInt16LE(&data[13]);  sensorPrime = data[15];  waypointDesiredBearing100 = readUInt16LE(&data[16]);  waypointActualBearing100 = readUInt16LE(&data[18]);  trackDir = data[20];
  desiredBearing100 = waypointDesiredBearing100;  actualBearing100 = waypointActualBearing100;
  Serial.println("RX: WAYPOINT DATA received");  Serial.print("pathTotalDistance = "); Serial.println(pathTotalDistance);  Serial.print("combinedStepsDesired = "); Serial.println(combinedStepsDesired);  Serial.print("oppositeDistance = "); Serial.println(oppositeDistance);  Serial.print("bearingAlignment = "); Serial.println(bearingAlignment);  Serial.print("reflectorBearing100 = "); Serial.println(reflectorBearing100);  Serial.print("sensorPrime = "); Serial.println(sensorPrime);  Serial.print("desiredBearing100 = "); Serial.println(desiredBearing100);  Serial.print("actualBearing100 = "); Serial.println(actualBearing100);  Serial.print("trackDir = "); Serial.println(trackDir);
  sendNavAck();  beginForwardNavigation();}
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {  switch (cmd) {    case CMD_STOP_MOTORS:      Serial.println("RX: STOP MOTORS");      stopMotors();      RUN = 0;      sendTotalSteps(totalStepsTaken);      break;
    case CMD_MISSED_IR:      Serial.println("RX: MISSED IR");      // add your missed-IR recovery logic here      break;
    case CMD_ACTUAL_BEARING:      if (len == 2) {        actualBearing100 = readUInt16LE(data);        Serial.print("RX: ACTUAL BEARING x100 = ");        Serial.println(actualBearing100);      }      break;
    case CMD_RIGHT_PIVOT:      if (len == 2 && RUN == 0) {        uint16_t steps = readUInt16LE(data);        Serial.print("RX: RIGHT PIVOT steps = ");        Serial.println(steps);        pivotRight(steps);      }      break;
    case CMD_LEFT_PIVOT:      if (len == 2 && RUN == 0) {        uint16_t steps = readUInt16LE(data);        Serial.print("RX: LEFT PIVOT steps = ");        Serial.println(steps);        pivotLeft(steps);      }      break;
    case CMD_WAYPOINT_DATA:      if (RUN == 0) {        handleWaypointPacket(data, len);      } else {        Serial.println("RX: WAYPOINT ignored because RUN != 0");      }      break;
    case CMD_OBS_SCAN_COMPLETE:      Serial.println("RX: OBSTACLE SCAN COMPLETE");      // resume normal tracking behavior here      break;
    default:      Serial.print("RX: Unknown command 0x");      Serial.println(cmd, HEX);      break;  }}
uint8_t getExpectedLength(uint8_t cmd) {  switch (cmd) {    case CMD_STOP_MOTORS:       return 0;    case CMD_MISSED_IR:         return 0;    case CMD_ACTUAL_BEARING:    return 2;    case CMD_RIGHT_PIVOT:       return 2;    case CMD_LEFT_PIVOT:        return 2;    case CMD_WAYPOINT_DATA:     return 21;    case CMD_OBS_SCAN_COMPLETE: return 0;    default:                     return 0xFF;  }}
void processIncomingByte(uint8_t b) {  switch (state) {    case WAIT_HEADER:      if (b == UART_HEADER) {        state = WAIT_CMD;      }      break;
    case WAIT_CMD:      currentCmd = b;      expectedLength = getExpectedLength(currentCmd);
      if (expectedLength == 0xFF) {        state = WAIT_HEADER;      } else if (expectedLength == 0) {        handlePacket(currentCmd, nullptr, 0);        state = WAIT_HEADER;      } else {        payloadIndex = 0;        state = WAIT_PAYLOAD;      }      break;
    case WAIT_PAYLOAD:      if (payloadIndex < sizeof(payload)) {        payload[payloadIndex++] = b;      }
      if (payloadIndex >= expectedLength) {        handlePacket(currentCmd, payload, expectedLength);        state = WAIT_HEADER;      }      break;  }}
void readIncomingUart() {  while (Serial3.available() > 0) {    uint8_t b = (uint8_t)Serial3.read();    processIncomingByte(b);  }}
void setup() {  Serial.begin(115200);  Serial3.begin(115200);  Serial.println("Arduino UART sketch v2 ready");}
void loop() {  readIncomingUart();
  if (RUN == 0) {    // setup / pivot / waypoint receive phase  } else if (RUN == 1) {    // forward navigation phase    // put your step counting / PWM correction / bearing logic here
    // TEST ARDU TX FUNCTIONS
delay(100);
If you need any additional clarification about how ARC Robot Skills are being used, the UART packet timing, or which variables ARC expects to be updated, let me know and I will provide that detail.
Thanks again, Jack
USB
Digital 21
Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands.
Script by Synthiam
Yes - that’s a very useful test result. Since UART_v3 disconnects even after only one pass through the loop, the problem is not the RX parser. It’s much more likely the script is hitting a Jint/ARC runtime issue in the loop body, or the UART skill call is failing in a way that drops the connection.
Let’s isolate it with a transmit-only UART_v3a.
UART_v3a: TX only, no RX
This version:
  • sends Waypoint Data once
  • can send Stop Motors and Actual Bearing on demand
  • has no receive logic
  • has a very simple loop
  • uses sleep(100) to reduce load
var UART_INDEX = 0;
var UART_HEADER = 0xA5;
// ARC -> Arduino
var CMD_STOP_MOTORS = 0x01;
var CMD_ACTUAL_BEARING = 0x03;
var CMD_RIGHT_PIVOT = 0x04;
var CMD_LEFT_PIVOT = 0x05;
var CMD_WAYPOINT_DATA = 0x06;
// Helpers
function u16ToBytes(value) {
  value = value & 0xFFFF;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
function u32ToBytes(value) {
  value = value >>> 0;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF,
    (value >> 16) & 0xFF,
function sendPacket(cmd, payload) {
  var packet = [UART_HEADER, cmd].concat(payload);
  UART.hardwareUartWrite(UART_INDEX, packet);
function sendStopMotors() {
  sendPacket(CMD_STOP_MOTORS, []);
  print("TX: STOP MOTORS");
function sendActualBearing() {
  var bearing100 = parseInt(getVar("$actualBearing100", 9000));
  if (isNaN(bearing100)) bearing100 = 9000;
  sendPacket(CMD_ACTUAL_BEARING, u16ToBytes(bearing100));
  print("TX: ACTUAL BEARING x100 = " + bearing100);
function sendWaypointData() {
  var pathTotalDistance = parseInt(getVar("$pathTotalDistance", 0));
  var combinedStepsDesired = parseInt(getVar("$combinedStepsDesired", 0));
  var oppositeDistance = parseInt(getVar("$oppositeDistance", 0));
  var bearingAlignment = parseInt(getVar("$bearingAlignment", 0));
  var desiredBearing100 = parseInt(getVar("$desiredBearing100", 9000));
  var trackDir = parseInt(getVar("$trackDir", 0));
  if (isNaN(pathTotalDistance)) pathTotalDistance = 0;
  if (isNaN(combinedStepsDesired)) combinedStepsDesired = 0;
  if (isNaN(oppositeDistance)) oppositeDistance = 0;
  if (isNaN(bearingAlignment)) bearingAlignment = 0;
  if (isNaN(desiredBearing100)) desiredBearing100 = 9000;
  if (isNaN(trackDir)) trackDir = 0;
  // Payload:
  // 0-3  pathTotalDistance
  // 4-7  combinedStepsDesired
  // 8-11 oppositeDistance
  // 12   bearingAlignment
  // 13-14 desiredBearing100
  // 15-16 reserved
  // 17   trackDir
  var payload = [];
  payload = payload.concat(u32ToBytes(pathTotalDistance));
  payload = payload.concat(u32ToBytes(combinedStepsDesired));
  payload = payload.concat(u32ToBytes(oppositeDistance));
  payload.push(bearingAlignment & 0xFF);
  payload = payload.concat(u16ToBytes(desiredBearing100));
  payload.push(0x00);
  payload.push(0x00);
  payload.push(trackDir & 0xFF);
  sendPacket(CMD_WAYPOINT_DATA, payload);
  print("TX: WAYPOINT DATA sent");
// Main
print("UART_v3a started");
var waypointSent = false;
while (true) {
  if (getVar("$sendWaypointNow", 0) == 1 && waypointSent == false) {
    print("$sendWaypointNow = 1, sending waypoint");
    sendWaypointData();
    setVar("$sendWaypointNow", 0);
    waypointSent = true;
    print("$sendWaypointNow: 0");
  if (getVar("$sendStopNow", 0) == 1) {
    sendStopMotors();
    setVar("$sendStopNow", 0);
  if (getVar("$sendActualBearingNow", 0) == 1) {
    sendActualBearing();
    setVar("$sendActualBearingNow", 0);
  print("loop");
  sleep(100);
Why this is the right next test
This removes:
  • RX parsing
  • packet receive state issues
  • extra variables like $run, $obsScan, $legComplete
  • any chance the crash is coming from processing incoming data
If this still disconnects, then the issue is almost certainly one of these:
  1. UART hardware skill naming / port configuration
  2. UART.hardwareUartWrite() behavior in your ARC version
  3. A project conflict because the UART skill is being started without the expected project state
  4. A malformed global variable or another skill reacting to the transmit
Test instructions
Please run UART_v3a by itself and tell me exactly:
  • Does it still disconnect?
  • Does it print TX: WAYPOINT DATA sent?
  • Does it continue printing loop more than once?
  • Does it crash only after sendWaypointData() or even before that?
One important question
Which UART skill are you using in ARC?
  • Hardware UART
  • Serial Terminal
  • another plugin UART skill
That matters because the command syntax can differ slightly depending on the skill.
If you want, after this test I can give you a UART_v3b transmit-only version that avoids UART.hardwareUartWrite() entirely and uses a different ARC method, just to isolate whether the write call itself is the trigger.
#34
@Athena. Boy, do I feel stupid. And you prompted me to check it when you sent:
  • Hardware UART
  • Serial Terminal
Guess what I was missing all this time?
UART.initHardwareUart(0, 115200);
I placed this at the top of the ROVER_CMD_v1 script, and everything seems to work just fine now. My other scripts had 'UART.init', but they are now long gone. I simply can't believe I overlooked something this elementary. I will do in-depth checking during the next week as I'm sure to have a few bugs yet. Can you please do a final write, let's call it v4, of ROVER_CMD, LEG_, and UART_? Also optimize Arduino to match ARC. Let's keep my oversight on the lowdown. Jack
Great catch - that missing UART.initHardwareUart(0, 115200); was the key. No need to dwell on it; the important part is that you found it and the system is moving again.
Below is a clean v4 package for:
  • ROVER_CMD_v4
  • LEG_v4
  • UART_v4
  • a matching Arduino sketch update
I’m also simplifying a few things so the ARC side and Arduino side stay aligned and easier to debug.
1) ROVER_CMD_v4
This is the startup coordinator. It initializes UART, starts the leg script, and starts the UART script.
print("ROVER_CMD_v4 started");
// Start Leg first so globals are ready
controlCommand("LEG_v4", "ScriptStartWait");
// Start UART after globals are loaded
controlCommand("UART_v4", "ScriptStart");
print("ROVER_CMD_v4 complete");
2) LEG_v4
This sets the navigation globals that UART_v4 will transmit to the Arduino.
This version keeps the payload aligned with the 18-byte waypoint format we standardized on.
print("LEG_v4 started");
// Example values - replace with your real leg data
setVar("$pathTotalDistance", 50000);
setVar("$combinedStepsDesired", 50000);
setVar("$oppositeDistance", 12000);
// 0 = DA, 1 = OA
setVar("$bearingAlignment", 1);
// desired bearing x100
setVar("$desiredBearing100", 8300);
// current actual bearing x100
setVar("$actualBearing100", 8300);
// 0 = forward, 1 = reverse
setVar("$trackDir", 0);
// State flags
setVar("$sendWaypointNow", 1);
setVar("$obsScan", 0);
setVar("$run", 0);
setVar("$legComplete", 0);
print("LEG_v4 complete");
3) UART_v4
This version is cleaned up to:
  • initialize safely
  • send waypoint once
  • send actual bearing on demand
  • send stop on demand
  • process Arduino responses
  • avoid the earlier loop instability
var UART_INDEX = 0;
// ARC -> Arduino
// Arduino -> ARC
var RSP_NAV_ACK = 0x10;
var RSP_TOTAL_STEPS = 0x11;
var RSP_DESIRED_BEARING = 0x12;
var RSP_OBS_SCAN_REQUEST = 0x13;
// Helpers
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
  return [
    value & 0xFF,
function bytesToU16LE(b0, b1) {
  return (b0 & 0xFF) | ((b1 & 0xFF) << 8);
function bytesToU32LE(b0, b1, b2, b3) {
    ((b1 & 0xFF) << 8) |
    ((b2 & 0xFF) << 16) |
    ((b3 & 0xFF) << 24);
  // 18-byte payload:
  // 15-16 reserved
  // 17   trackDir
  var payload = [];
  payload.push(0x00);
  payload.push(0x00);
// RX parser
var rxState = 0; // 0=wait header, 1=wait cmd, 2=wait payload
var rxCmd = 0;
var rxExpected = 0;
var rxPayload = [];
var rxIndex = 0;
function expectedLengthForCmd(cmd) {
  if (cmd == RSP_NAV_ACK) return 0;
  if (cmd == RSP_TOTAL_STEPS) return 4;
  if (cmd == RSP_DESIRED_BEARING) return 2;
  if (cmd == RSP_OBS_SCAN_REQUEST) return 0;
  return -1;
function handleRxPacket(cmd, payload) {
  if (cmd == RSP_NAV_ACK) {
    print("RX: NAV ACK");
    setVar("$run", 1);
    return;
  if (cmd == RSP_TOTAL_STEPS) {
    if (payload.length >= 4) {
      var steps = bytesToU32LE(payload[0], payload[1], payload[2], payload[3]);
      print("RX: TOTAL STEPS = " + steps);
      setVar("$totalStepsTaken", steps);
      setVar("$legComplete", 1);
    return;
  if (cmd == RSP_DESIRED_BEARING) {
    if (payload.length >= 2) {
      var bearing100 = bytesToU16LE(payload[0], payload[1]);
      print("RX: DESIRED BEARING = " + (bearing100 / 100.0));
      setVar("$desiredBearing100", bearing100);
    return;
  if (cmd == RSP_OBS_SCAN_REQUEST) {
    print("RX: OBSTACLE SCAN REQUEST");
    setVar("$obsScan", 1);
    return;
  print("RX: Unknown command = 0x" + cmd.toString(16));
function processIncomingBytes() {
  var available = UART.hardwareUartAvailable(UART_INDEX);
  while (available > 0) {
    var b = UART.hardwareUartRead(UART_INDEX, 1)[0];
    available--;
    if (rxState == 0) {
      if (b == UART_HEADER) rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxExpected = expectedLengthForCmd(rxCmd);
      rxPayload = [];
      rxIndex = 0;
      if (rxExpected == 0) {
        handleRxPacket(rxCmd, rxPayload);
        rxState = 0;
      } else if (rxExpected > 0) {
        rxState = 2;
      } else {
        rxState = 0;
      continue;
    if (rxState == 2) {
      rxPayload.push(b);
      rxIndex++;
      if (rxIndex >= rxExpected) {
        rxState = 0;
        rxCmd = 0;
        rxExpected = 0;
        rxPayload = [];
        rxIndex = 0;
      continue;
// Main loop
print("UART_v4 started");
while (true) {
    sendStopMotors();
    sendWaypointData();
  processIncomingBytes();
  sleep(20);
4) Arduino optimization to match ARC
Since ARC is now stable, the Arduino should stay simple and predictable. The most important changes are:
  • match the 18-byte waypoint payload
  • keep NAV ACK, TOTAL STEPS, DESIRED BEARING, OBS SCAN REQUEST
  • update actualBearing100 and bearingDiffTarget immediately on CMD_ACTUAL_BEARING
  • use neutral correction during scan request, but keep moving
  • make pre-run pivots blocking
  • use step-pulse totals for distance
If you want, I can provide the final corrected Arduino v4 sketch next in one clean paste, aligned exactly to this ARC v4 package.
In ARC:
  1. ROVER_CMD_v4
  2. which runs LEG_v4
  3. then starts UART_v4
And make sure UART.initHardwareUart(0, 115200); stays in ROVER_CMD_v4 before the skills start.
6) One question before I write the Arduino v4
Do you want the Arduino v4 to:
  • keep the current 18-byte waypoint format, or
  • expand back to the original 23-byte format you described earlier?
My recommendation is to keep the 18-byte format, because it is already working with your current ARC flow.
If you want, I can now write the final Arduino v4 to match this exactly.
#36
@Athena. Yes, please write the Arduino_v4 sketch and keep the 18-byte waypoint format. Thank you. Jack
#37
@Athena. BTW did you want to keep 'var waypointSent = false' in the MAIN LOOP of UART_v4? Thanks Jack.
Yes - keep var waypointSent = false; in UART_v4.
It’s useful because it prevents the waypoint packet from being sent repeatedly every loop once $sendWaypointNow is set. With this pattern:
  • the packet sends once
  • the flag gets cleared
  • waypointSent blocks accidental resends
That said, if you later want to send a new waypoint for each leg, you should reset waypointSent = false when a new leg starts, otherwise UART_v4 will only transmit the first waypoint.
When a new leg begins in LEG_v4 or ROVER_CMD_v4, set:
And in UART_v4, keep:
Then if you want to reuse UART for another leg in the same session, reset it at the start of the next leg:
One important note
Because waypointSent is a local script variable, it will reset if the script stops and restarts. So it’s fine to keep as-is for a single run, but if you expect UART_v4 to stay running continuously across multiple legs, I can also show you a cleaner version that uses a global ARC variable like:
setVar("$waypointSent", 0);
That makes it easier to manage across script restarts.
If you want, I can now give you the full Arduino_v4 sketch next, matched to the 18-byte waypoint format and the current UART_v4 behavior.
#39   — Edited
@Athena. I expect UART_v4 to stay running continuously across multiple legs, please show a cleaner version that uses a global ARC variable like:
That makes it easier to manage across script restarts. Please send a UART_v4 that is a cleaner version using an ARC global variable. Also please send and Arduino_v4 that will match UART_v4. Thanks. Jack
Absolutely - for a continuous multi-leg run, a global ARC variable is the cleaner choice.
Use:
That way:
  • the flag survives script restarts better than a local variable
  • you can reset it when starting a new leg
  • it stays aligned with your ARC state machine
Below is a cleaned-up UART_v4 and a matching Arduino_v4 sketch using the 18-byte waypoint format.
UART_v4
This version:
  • initializes hardware UART safely
  • sends waypoint data once per leg using $waypointSent
  • handles ARC Arduino packets
  • processes Arduino ARC packets
  • avoids the earlier disconnect issue by keeping the loop simple
var UART_INDEX = 0;
// ARC -> Arduino
// Arduino -> ARC
// Helpers
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
  return [
    value & 0xFF,
  return (
    (b0 & 0xFF) |
    ((b3 & 0xFF) << 24)
  ) >>> 0;
  // 18-byte payload:
  // 0-3  pathTotalDistance      uint32
  // 4-7  combinedStepsDesired   uint32
  // 8-11 oppositeDistance       uint32
  // 12   bearingAlignment       uint8
  // 13-14 desiredBearing100     uint16
  // 15-16 actualBearing100      uint16
  // 17   trackDir               uint8
  var payload = [];
  payload = payload.concat(u16ToBytes(parseInt(getVar("$actualBearing100", 9000))));
// RX handling
var rxState = 0; // 0=wait header, 1=cmd, 2=payload
var rxCmd = 0;
var rxExpected = 0;
var rxPayload = [];
var rxIndex = 0;
  return -1;
    setVar("$run", 1);
    return;
    return;
    return;
    return;
    available--;
    if (rxState == 0) {
        rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxPayload = [];
      rxIndex = 0;
        rxState = 0;
        rxState = 2;
      } else {
        rxState = 0;
      continue;
    if (rxState == 2) {
      rxPayload.push(b);
      rxIndex++;
        rxState = 0;
        rxCmd = 0;
        rxExpected = 0;
        rxPayload = [];
        rxIndex = 0;
      continue;
// Main
if (getVar("$waypointSent", 0) == "") {
while (true) {
  if (getVar("$sendWaypointNow", 0) == 1 && getVar("$waypointSent", 0) == 0) {
    sendWaypointData();
    setVar("$waypointSent", 1);
    print("$waypointSent = 1");
    sendStopMotors();
  sleep(20);
Arduino_v4
This version matches the UART_v4 packet layout and behavior.
It includes:
  • correct UART parsing
  • 18-byte waypoint payload
  • actual bearing update handling
  • desired bearing change threshold of 100 = 1.00 degree
  • step-based progress tracking
  • obstacle scan request behavior
  • neutral steering during scan request while motion continues
  • blocking pivots in pre-run
  • stepper control with your DRV8825 setup
#include <AccelStepper.h>
#include <MultiStepper.h>
// -------------------- UART PACKETS --------------------
// ARC -> Arduino
// Arduino -> ARC
// -------------------- STEPPERS --------------------
// DRV8825 STEP/DIR
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
MultiStepper multiStepper;
// -------------------- PARSER --------------------
enum ParserState { WAIT_HEADER, WAIT_CMD, WAIT_PAYLOAD };
// -------------------- NAV STATE --------------------
int RUN = 0; // 0 = pre-run, 1 = forward run
uint8_t bearingAlignment = 0; // 0 = DA, 1 = OA
uint16_t waypointDesiredBearing100 = 9000;
uint16_t waypointActualBearing100 = 9000;
uint8_t trackDir = 0; // 0 = FD, 1 = RD
uint16_t actualBearing100 = 9000;
uint16_t desiredBearing100 = 9000;
uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;
int16_t bearingDiffRamped = 0;
bool obstacleScanRequested = false;
uint32_t lastObstacleScanStep = 0;
bool scanNeutralMode = false;
uint16_t scanNeutralSpeed = 400;
uint16_t normalSpeed = 800;
uint16_t currentSpeed = 0;
uint16_t rampIncrement = 10;
// If you want more/less frequent scan requests, adjust this.
// 24 inches * 437.5 steps/inch = 10500 steps
const uint32_t scanIntervalSteps = 10500;
// -------------------- BYTE HELPERS --------------------
  Serial3.write(cmd);
void sendNavAck() {
  lastSentDesiredBearing100 = bearing100;
// -------------------- MOTOR HELPERS --------------------
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {
  LeftFrontWheel.setSpeed(leftSpeed);
  LeftBackWheel.setSpeed(leftSpeed);
  RightFrontWheel.setSpeed(rightSpeed);
  RightBackWheel.setSpeed(rightSpeed);
void stopMotors() {
  LeftFrontWheel.stop();
  LeftBackWheel.stop();
  RightFrontWheel.stop();
  RightBackWheel.stop();
  LeftFrontWheel.setSpeed(0);
  LeftBackWheel.setSpeed(0);
  RightFrontWheel.setSpeed(0);
  RightBackWheel.setSpeed(0);
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() + steps;
  positions[1] = LeftBackWheel.currentPosition() + steps;
  positions[2] = RightFrontWheel.currentPosition() - steps;
  positions[3] = RightBackWheel.currentPosition() - steps;
  multiStepper.moveTo(positions);
  while (multiStepper.run()) {
    // blocking pivot
  totalStepsTaken += steps;
  stopMotors();
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() - steps;
  positions[1] = LeftBackWheel.currentPosition() - steps;
  positions[2] = RightFrontWheel.currentPosition() + steps;
  positions[3] = RightBackWheel.currentPosition() + steps;
    // blocking pivot
  stopMotors();
  RUN = 1;
  currentSpeed = 0;
  lastObstacleScanStep = totalStepsTaken;
// -------------------- BEARING MATH --------------------
void computeDesiredBearing() {
  if (bearingAlignment == 0) {
    return;
  if (combinedStepsDesired == 0) return;
  uint32_t pathDistanceRemaining = 0;
  if (trackDir == 0) {
    if (pathTotalDistance > totalStepsTaken) {
      pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
    } else {
      pathDistanceRemaining = 1;
  } else {
    if (pathTotalDistance > (combinedStepsDesired - totalStepsTaken)) {
      pathDistanceRemaining = pathTotalDistance - (combinedStepsDesired - totalStepsTaken);
    } else {
  if (pathDistanceRemaining == 0) pathDistanceRemaining = 1;
  float tangent = (float)oppositeDistance / (float)pathDistanceRemaining;
  float deg = atan(tangent) * 180.0 / PI;
  desiredBearing100 = (uint16_t)((deg + 90.0) * 100.0);
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {
    sendDesiredBearing(desiredBearing100);
void updateBearingDiff() {
  bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
  if (bearingDiffRamped < bearingDiffTarget) {
    bearingDiffRamped += 10;
    if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
  } else if (bearingDiffRamped > bearingDiffTarget) {
    bearingDiffRamped -= 10;
    if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
// -------------------- WPT HANDLING --------------------
  if (len != 18) {
    return;
  waypointDesiredBearing100 = readUInt16LE(&data[13]);
  waypointActualBearing100 = readUInt16LE(&data[15]);
  trackDir = data[17];
  sendNavAck();
// -------------------- PACKET HANDLING --------------------
  switch (cmd) {
    case CMD_WAYPOINT_DATA: return 18;
  switch (cmd) {
      stopMotors();
      RUN = 0;
      break;
      if (len == 2) {
        updateBearingDiff();
      break;
        pivotRight(readUInt16LE(data));
      break;
        pivotLeft(readUInt16LE(data));
      break;
      if (RUN == 0) {
      } else {
      break;
  switch (state) {
    case WAIT_HEADER:
      if (b == UART_HEADER) state = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      } else {
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
// -------------------- SETUP / LOOP --------------------
void setup() {
  LeftFrontWheel.setMaxSpeed(2000);
  LeftBackWheel.setMaxSpeed(2000);
  RightFrontWheel.setMaxSpeed(2000);
  RightBackWheel.setMaxSpeed(2000);
  LeftFrontWheel.setAcceleration(800);
  LeftBackWheel.setAcceleration(800);
  RightFrontWheel.setAcceleration(800);
  RightBackWheel.setAcceleration(800);
  multiStepper.addStepper(LeftFrontWheel);
  multiStepper.addStepper(LeftBackWheel);
  multiStepper.addStepper(RightFrontWheel);
  multiStepper.addStepper(RightBackWheel);
  Serial.println("Arduino_v4 ready");
void loop() {
  readIncomingUart();
  if (RUN == 0) {
    // pre-run mode: wait for pivots and waypoint
    // ramp up speed
    if (currentSpeed < normalSpeed && !scanNeutralMode) {
      currentSpeed += rampIncrement;
      if (currentSpeed > normalSpeed) currentSpeed = normalSpeed;
    // compute and send desired bearing if needed
    computeDesiredBearing();
    // ramp bearing correction
    // If scan request is active, keep rover moving but neutralize differential
    int leftSpeed = currentSpeed;
    int rightSpeed = currentSpeed;
    if (scanNeutralMode) {
    } else {
      int correction = bearingDiffRamped / 10;
      leftSpeed -= correction;
      rightSpeed += correction;
    setAllMotorSpeeds(leftSpeed, rightSpeed);
    // Run steppers
    LeftFrontWheel.runSpeed();
    LeftBackWheel.runSpeed();
    RightFrontWheel.runSpeed();
    RightBackWheel.runSpeed();
    // Use accumulated step targets
    totalStepsTaken =
      abs(LeftFrontWheel.currentPosition()) +
      abs(LeftBackWheel.currentPosition()) +
      abs(RightFrontWheel.currentPosition()) +
      abs(RightBackWheel.currentPosition());
    // Scan request about every 24 inches
    if (!obstacleScanRequested &&
        totalStepsTaken > 0 &&
        (totalStepsTaken - lastObstacleScanStep) >= scanIntervalSteps) {
      sendObstacleScanRequest();
      obstacleScanRequested = true;
      scanNeutralMode = true;
      Serial.println("Obstacle scan active, steering set neutral");
    // Leg complete
    if (totalStepsTaken >= combinedStepsDesired && combinedStepsDesired > 0) {
      stopMotors();
      RUN = 0;
      Serial.println("Leg complete");
Notes
About $waypointSent
Yes, in this global version, you should initialize it in LEG_v4 or ROVER_CMD_v4:
Then when a new leg starts, reset it again:
About the 18-byte waypoint format
This version uses:
  • pathTotalDistance = 4 bytes
  • combinedStepsDesired = 4 bytes
  • oppositeDistance = 4 bytes
  • bearingAlignment = 1 byte
  • desiredBearing100 = 2 bytes
  • actualBearing100 = 2 bytes
  • trackDir = 1 byte
Total = 18 bytes
One thing I want to confirm
For your actual production flow, do you want the Arduino to:
  1. continue moving during scan request with neutral steering, exactly as above, or
  2. pause step speed briefly during the scan request and then resume?
I assumed continue moving, since that matches what you described.
If you want, I can next give you:
  • a cleaned up ROVER_CMD_v4
  • a slightly more defensive LEG_v4
  • or a UART_v4b with extra debug prints for first-run validation
