TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Arm - Help Me!
Hello, I wonder if it's possible I ride a robotic arm with a camera reading with your card ... I wish the controller reads the object and separate it by color. can do with your board?
I have a robotic arm of 1.10 meters, and is controlled with a few servants. but I want to change .. want to use your card ... she is hotter to work for what I've been reading.
thks DJ
Ah I think he saying he wants to replace the motor in his servo with the windshield motor while still using the servo board. MetronRick, the pc board probably is rated to only 1 amp and so this will not work. I'm heading out the door so maybe someone can suggest an alternative. The simple way is like mentioned above and use a strong servo.
Brazil
Ola MtronRick, talvez eu possa ajuda-lo... Qual a sua dvida? Vou traduzir para a comunidade.. Abracos
tevans eu precisava de um servo motor forte, queria saber se posso tirar o motor do servinho, e substituir a saida do motor do servo, e colocar uma ponte h, e ligar o motor de parabrisa... pode ser feito assim?
