Hi there - looking for a 3D print file for the bracket that is screwed onto the side on JD's body where the arm servo slides into... a little kiddie wiggled a little too hard...
— Edited
UBTECH Alpha Servos UBT-12HC
— Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping.
you mean this?
CHOULDER PART
Thanks, I just checked and the smaller piece is there!
adhartwell
great.you can also by the molded part here on ez robot.
Great - you found it
All of the 3d printable files are associated with each product on their page as well. You can look at the product page for JD Humanoid and click the tab CAD FILES. This applies with all of the ez-robots
