As New As New Can Be
I don't know how I stumbled on this site a week ago but since I've started reading about everyone's projects, in that week I've already purchased my Omnibot on eBay and put in my order for my ARC kit.
I've been fascinated with robots since I was a kid and been a mild tinkerer all my life, but never have I tried to embark on a project of this magnitude. The closest I've gotten to a robot in my adult life is the tattoo of a robot I have on my leg.
Just a fair warning, I'm sure I'll be on here asking a million questions during my build process. Thanks everyone in advance for all your help.
Adam
#17
You will need a TIP120 transistor you can get at RadioShack - Linky and a 1K resistor. I will find a schematic on the wiring and post it for you.
On the holes, I used some clear refractive plastic (an old camera filter I had) and glued it in place behind the chest panel. I used two 3mm LEDs and just mounted them in the two holes on the bottom left. Then 5mm LEDs everywhere else. When I wired them up I used two LEDs per output of the board. Then I just hot glued everything in place.
#18
Wow, great. I pass Radio Shack after work, I'll stop by. Yes please let me know how to wire this, never done it before. Sounds straight forward on the rest, now that I have an idea of what to do to cover the holes with. I am ordering the eBay kit today. Thanks a great deal, I would not know what to do without your expertize. Omni needs lights, heh
Thanks again, I am sure I will have more questions, as I progress,if your up for it, lol
Folon
#19
Hey all,
 I got the motor tested and he moves well.  After melting battery leads, and burning my hand, I have finally realized the importance of electrical tape,.. no worries I'm fine and Omnibot still works.  I was wondering if you got the schematic of wiring the kit 1 to the EZ-board.  I have some assembly done on the light chaser and was wondering where the 1k resistor and tip120 goes?  The kit has a tip like transistor and I did not know how the other transistor plays into the wiring?  Any help is appreciated, thanks!!
Folon
#21
Thanks!! I am not sure this makes since to me. I don't quite know how to read this. (I am a beginner with electronics, sorry) stress
This is to go in front of the chaser kit (device)? Then the B E C wires go to a normal servo connector for the digital side of the EZ_Board to power/on off switch? I just confused how this routes to the battery, EZ-Board and chaser kit,.. So:
  1. Wire a wire form positive on kit to positive on batt.
  2. Wire tip120 E to negitive on batt.
  3. Wire C to negitive on kit.
  4. Wire B to resistor 1k then another wire from there to, where?
Sorry and thanks for any help,.. just don;t wnat to blow up any more things,. lol that's how I learn I guess,.. lol
#22
  1. Powering from the EZ-B you would do the following: Using a standard servo connector, connect the red (+) wire from the LED Kit to the red (+) wire of the servo connectior. Connect the black (-) wire from the servo connector to the E pin of the transistor. Connect the black (-) wire from the LED Kit to the C pin of the transistor. Connect the white (signal) wire of the connector to a 1K resistor and then connect that to the B pin of the transistor. Plug the servo connector wire to the EZ-B and you are good to go.
  2. Powering from a larger source (direct to the battery) just connect the red (+) from the LED Kit to the red (+) terminal of the battery and don't use the one on the servo connector. However, you MUST use a common ground - the same ground from this battery must be the same ground to the EZ-B - you are just bypassing the EZ-Bs drop in voltage to the DIOs and using straight voltage from the battery.
I hope that is clear enough for you.
#23
@ falon , I tested the regular omnibot base with 40 pounds of weight and still trucked along fine , no stalling and drew 3 amps current. If you want to make the led area usable there are cheap LCD kits that fit in that spot. On mine I have it showing battery charge level , battery temp , current draw and avg watts used.
I have not done it yet and won't till after paint but I will use one of those switching transistors to turn on LEDs and my led spot lights.
#24
Yes, thank you I think I get it now; it is not as easy as I had hoped but I will give that a shot. With your instructions I should be good, thanks a million!!
Jstarne1, that sounds like those old motors are pretty tough to haul 40lbs!! I like your display concept; sounds like you know what you are doing. I'm still having issues with the light chaser kit I bought and how it intergrates to the EZ-Board, but with time and patience and great instructions from Bret, I am sure I will have it blinking in no time,.. sheesh all this trouble to make a Christmas tree lights blink, lol. Just excited my Omnibot's motors work and I can finish my teardown/paint job. I am a bit behind, but I see that that is normal with these things looking at all the forum links. I just hope I can get the amp controller to work with the h-bridge next,..
Still a newbe,.. and not many tools
Thanks, for the continued support,
Folon
