Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
Assembly Instructions
Step 1 of the instructions cover connecting the H-Bridge to the digital ports, but make no mention of which pin of the three pins per port (Black, Red, White) to connect to nor do they mention the red/black pair connection.
The next lesson describes in detail how to make all these connections.
Shouldn't the "Connecting Roli's Motors (H-Bridge) lesson proceed the "Roli Assembly instructions" and step 1 also be removed from the later instructions?
