When setting up an Auto Position Frame, how do I select which EZB Controller?
RichardZ
Bing Speech Recognition
— Accurate Bing cloud speech-to-text for ARC: wake-word, programmable control, $BingSpeech output, Windows language support, headset compatible
RichardZ
holy1
see this topic.
choose ezbv4
Hi Nomad 6R
Thanks, I had seen this but it is not the same thing.
@Holy1 not using a single auto positioner you can't ... Just write simple scripts (using the cheat sheet/control commands) to drive frames or actions on 2 or more different boards. This way you can can control one or more auto-positioner controls at once... e.g... Fingers move in one auto-positioner at the same time head moves in another auto-positioner control... and so on...
@Richard.
Thanks, I will work on that as learning scripting is next on the list as my Inmoov is ready to go ( as much as I am going to do for now) .
Yeah - create a different Auto Position for different servo groups. Such as one for the fingers, and one for everything else...
then you can execute them like so in ez-script..
I can see that the AutoPosition control (non movement) can be set to EZB 0-4 but AutoPosition (movement) is defaulted to EZB 0
Is this correct ?
Frank
Yes, all movement panels are EZ-B 0 only.
Just for clarity, you can only have one Movement Panel per project but that Movement Panel can be assigned to any EZB. An Autopostion with Movement Panel can only be EZB-0.
