Kinect Body Control icon Kinect Body Control — Control robot servos with Microsoft Xbox 360 Kinect body tracking; map joints to upper/lower body servos with smoothing and pause control. Try it →
Auto Shut Down Of Ezb And Computer?
I have been successful with the Help of Alan (@thetechgruru) in having my robot automatically start by applying power to the EZB and starting my computer. This allows the robot to fully activate.
I have built a script that upon verbal command I can get the program and the EZB to shut down.
My next goal is to have this verbal command disconnect the EZB and shut off the computer. I know there is a command to disconnect the EZB which I can add to the verbal shut down script. I can also add a relay which applies and removes the EZB power prior to startup and after shut down.
My question is: Is it possible to shut off the computer from the EZB ?
#17
Oops... In re-reading the text from Alan he said I still need to do the Start Script. I will give it a try.
#18
Hi Alan, Posts crossed... So if I leave the start as is with the loop, it should be fine. Then I just need the shutdown script to close running scripts and command the hibernate function.
When this works, I can use the embedded computer as planned. Thanks
#19
Final Update !
Works great !
Antonn will finally getting his own Brain !
THANK YOU TO ALL THAT HELPED
#20
Huzzah! :D
This was a good thread. I learned something also! Thanks.
#21
Fantastic! And nice to see the collaborative effort of everyone who responded.
